  #1
Old March 29th, 2008, 08:39 PM
brodriguez brodriguez is offline
Default prop stainless or aluminum
does it make a big difference if you go to a stainless prop instead of aluminum any one have good info on that
  #2
Old March 29th, 2008, 09:40 PM
tnduc's Avatar
tnduc tnduc is offline
Default Re: prop stainless or aluminum
I just replaced my old aluminum prop with a used stainless prop. Same pitch, everything. Today was the first day on the water with it and the difference was noticable. Boat popped up on plane much quicker and ran a little faster at same throttle position.
__________________
"Avoiding danger is no safer in the long run than outright exposure. The fearful are caught as often as the bold" - Helen Keller
  #3
Old March 30th, 2008, 12:29 PM
thanks a bunch
  #4
Old March 30th, 2008, 01:22 PM
Frank Acampora's Avatar
Frank Acampora Frank Acampora is offline
The only thing I use my aluminum props for are emergency spares. There is no question that a stainless prop is worth the extra money you pay for it.
The only time a stainless prop might be contraindicated would be if you boat in water where the probablity of hitting something is very high. Then you need to weigh off the disadvantage of possible damage to the lower unit and higher cost of repairing the stainless prop to its advantages.
Generally, because of the thinner blades, reduced drag in the water, and reduced flex over aluminum, a stainless prop of the same model, diameter, and pitch will run 2-400 rpm faster at wide open throttle with a gain of around 2 MPH.
  #5
Old March 30th, 2008, 06:17 PM
alanaexall alanaexall is offline
Red face Re: prop stainless or aluminum
i was warned not to put a stainless prop on. i should have listen to that advice. yes the boat went better, and that shiny thing looked good. all i did was just touch a rock with it, no damage to the prop but bent the propshaft causing 1500 uk pounds damage. so i say, if theres a chance you will hit something, stick to ally it bends easily and is cheaper to fix. please no replies telling me i should be more carefull. shes done that already
  #6
Old April 2nd, 2008, 04:06 PM
tnduc's Avatar
Quote:
I thought that the prop's hub and bushing was supposed to prevent this from happening ?
__________________
  #7
Old April 3rd, 2008, 03:06 PM
so did we , but it seems not in my case. the motor was at just a 1000 revs. so we were shocked to see the shaft twisted.
  #8
Old April 3rd, 2008, 04:20 PM
Silvertip Silvertip is offline
At 1000 engine rpm, the prop is spinning at about 500 RPM. Damage occurs instantly whereas the rubber hub takes a fair amount of twist before it lets go.
  #9
Old April 3rd, 2008, 09:43 PM
tnduc's Avatar
Quote:
Well, that's comforting seeing how I just installed a stainless prop . Fortunately there are not many rocks here, just lots of sandbars and mud.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
aluminum prop to stainless fourwinner Prop Questions and Topics 1 April 20th, 2007 01:30 AM
Stainless or Aluminum Prop? Rushin Non-Repair Outboard Discussions 23 January 6th, 2003 06:08 PM
stainless vs aluminum prop h2oTherapy Non-Repair Outboard Discussions 4 May 6th, 2002 05:22 PM
Prop, aluminum vs. stainless gobydon Mercury & Mariner Outboards 2 October 11th, 2001 01:40 PM
Aluminum Vs Stainless Prop fritchey Johnson & Evinrude Outboards 4 August 23rd, 2001 10:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
