Re: 75 evinrude overheating
When was the impeller last changed? If you are unsure, or it has been a couple years, it is time. They should definately be changed every 2 to 3 years. Cheap part, but its failure is catastrophic. I would probably change the t stats and poppets while I was at it as well, flushing out the water line.
