Looking to do a jon boat deck and floor, and wouldn't need a ton of this stuff, but the benefits are great. Easy to clean, no need to epoxy plywood and cover it with vinyl or carpet. Just looks to be so much nicer to use, nicer to implement, timewise, and for a small application that it's cost would be OK and worth doing.
But, what concerns me is expansion/contraction. Their website says this...
Test applications for unforeseen complications, such as expansion/contraction issues (note: different colors react differently to heat). King StarBoard? contracts and expands at a rate of 6x10-5 in./degree F, changing approximately 1/32 inch for every foot of length or width over a 40-degree temperature range
1/32 inch for every foot over 40 degrees? The sun can make a boat deck's temp too hot for bare feet, and in winter under a tarp here nightime can be under 20 degrees. So over a 100 degree swing in temp, if not more. And easily 40 degree swings daily regarding nightime temp vs daytime sun temp (not air temp, but sun beating down on it). And my floor would be at least a 6 foot length, 4 foot wide. How do you fasten this down so it can move that much, yet still remain fastened and feel solid so as not to tap the ribs when walking on it? I know you "hang" vinyl on a house, not nailed in tight so it can contract and expand, but this Starboard seems unusable for my jon boat application unless someone is using it this way and has good experience with it. Strength is not the issue for me. Ribs are 12 inches apart and the aluminum underdeck structure I'd build would also suffice, but this expansion is concerning.
Anyone have any experiences with this product in wide ranging temperatures? I REALLY like the other aspects of this product, but this one aspect is tough to look beyond.
