  #1
Old March 29th, 2008, 04:55 PM
pine island fred pine island fred is offline
Master Chief Petty Officer
Default Yamaha, no instrumts/no crank
Am faced with a weird problem. It is a recently repowered with a OX66, 200 hp. 03 vintage, replacing an older carbed 200. Old instruments were replaced with yamaha digital ones, one the tach the other spedo with the associated other indications in those instruments. Problem has come up like this. Turn the key on and nothing happens. No power to the starter and no power to the instruments. Turn on the boat supplied instrument lights switch and the instruments display and the starter will engage. Have found that the instruments do light up for nite operation.
I have a similar set up with the tach gague only but do not know if it lights up or not as I do not go out at night. Any ideas? Are the instruments normally lite up with the key on or are the display and background lighting seperate? I am suspicious that somehow the lighting is back energising the rest of the system. The tilt/ trim sym. is operating normally from the throttle and motor switch with the key off as I suspect it is supposed to. Would appreciate any ideas if you have run into this. regards FRED
  #2
Old March 30th, 2008, 11:10 AM
Ray Neudecker Ray Neudecker is offline
Default Re: Yamaha, no instrumts/no crank
Normally the yellow wire should be the postive wire for the guages ect. The blue wire is run through the light switch so it only goes postive when the light switch is on. First check to be sure the yellow wire is going hot when the key switch is on. If not you have a switch problem. If it is check the wiring to the guages.
  #3
Old April 1st, 2008, 08:03 PM
RAY, thankyou for the response. Boat is now a 1000 miles away so someone else will have to tear into it. Something will have to be does as when the engine operation degrades to the point of turning on the panel light switch to operate the engine, something is wrong.
My limited experience, wiring boats I never tap off the engine harness at all. Easy to grab power off the ignition switch but I run seperate power with a switch to power the nav, accessory bus. I believe in keeping the buses isolated. FRED
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
40 hp yamaha won't crank bill wade Yamaha & Suzuki Outboards 1 July 31st, 2006 03:05 AM
95 Yamaha Waverunner Won't Crank! 111abeach PWC (Jetskis, Waverunners, etc.) 5 July 11th, 2005 05:14 AM
'01 Yamaha 50 hp - crank but no start??? SmokinBarrel Yamaha & Suzuki Outboards 7 February 25th, 2004 07:54 AM
200 yamaha crank ocean goin Yamaha & Suzuki Outboards 2 July 17th, 2003 06:41 PM
Yamaha 250 Won't continue to crank tilted fishon71 Yamaha & Suzuki Outboards 0 July 22nd, 2002 10:07 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
