Just got back from a little engine work. V8 Chevy OMC. 1986.
Getting ~120 psi on all cylinders except #3 at 50 psi and #4 at 90 psi. Squirted some oil into both, with no change in compression.
#3 spark plug looked different than all the others: damp (I assume oil, didn't evap like gas) and the conductor looked like it hadn't seen much spark.
Does this sound like a valve problem? Where do I go from here? No milk in the oil pan, and no oil consumption.
Also, checked the timing, and it was roughly at 30 BTDC (off the scale). I put it down to 13 BTDC per the OMC book. Is that way off, or is it normal to have it drift that far? The lock bolt on the distributer seemed tight enough, so I was surprised to see it so far off. Would that have caused significant power loss, and is there any damage I should look for?
Also, when I pulled the drain plugs for the exhaust manifolds, I got a whole lot of rusty looking debris coming out. I'm talking fingernail sized flakes of hard oxidized material. What's going on here?
Thanks in advance!!!
