Re: how remove oil seals
Not too familiar with that engine but usually seals are removed with a hook, a seal puller, or a screwdriver. You hook any tool under it and pull or pry up. The seal is always destroyed during removal. Just put a small plate under the tool to cushion the aluminum casting so you don't groove it.
