Re: ? about dual battery switch
Hi Blipship,<br /><br />First, you need to make sure that ONLY the starter is hooked up to your starting battery, and that the starting battery is hooked up to switch #1. Second, attach ALL other wiring to the #2 battery, and battery #2 to switch #2. ALWAYS, unless you are to dead and have to use both batteries to start, use ONLY the #1 switch/battery to start the engine. Once started, switch the switch to both, and you will charge both batteries while running. If you are sitting, engine off, only use #2.<br /><br />To answer your question more directly, the benefit is that you can always leave your starting battery alone, and use only to start the boat. And, yes, you do charge both batteries while running when you have the switch on both.
