  #1
Old March 26th, 2008, 09:34 PM
Waterlogged_xj Waterlogged_xj is offline
Default 1990 evinrude 70hp, stalls @ wot
Hello everyone,
My old name wouldn't let me on, so I had to make a new one...
Anyway, I was on here last summer and recieved tons of help and info on some minor repairs by many of you and really appreciate it!
Heres the deal:
I have a 1990 evinrude 70hp that bogs down @ wot. It idles great and runs its' balls off @ 3/4 throttle, but as soon as I open it up, it bogs down. Kinda like it's starving for fuel. I had my buddy pump the primer bulb during the bogging and there was no improved response, just seems like I was flooding it. There is new gas in there too.
So we broke the carbs down and dunked them in chem dip for about 20 mins each, carb cleaned them, compressed air ran through, and sprayed them again w/ carb clean. We adjusted the floats per the carb kit instructions which was 3/4" down from float bowl and then checked if the float was parallel w/ float bowl when inverted. We then adjusted the idle screw all the way in and then backed it out 3 1/2 turns on all. That all check out and it still fallls on its' face @ wot?
The service manual says to set them floats at 1 1/8" - 1 5/8"... We are going to try that tomorrow if the rain breaks.
Can you guys please help me out once again?
Thanks!
Jeff
  #2
Old March 26th, 2008, 09:56 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: 1990 evinrude 70hp, stalls @ wot
Jeff did you get to the high speed jet and clean it thoroughally? Will choking improve things?
Also is this a portable fuel tank or built in?
__________________
Chris
  #3
Old March 26th, 2008, 10:02 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
as Chris asked did you use the special screwdriver to remove the high speed jets. picture below. also this. http://forums.iboats.com/showthread.php?t=167352
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old March 26th, 2008, 10:09 PM
Thanks for the quick reply!
Yes, we cleaned the high speed jets out and the entire carb thoroughly... Choking it from the primer soleniod manually (engine running) will kill it. Tanks are removable too.
  #5
Old March 26th, 2008, 11:39 PM
jtexas's Avatar
jtexas jtexas is offline
If the hi-speed jets are good, a misadjusted float would be a good next place to look. hold it upside down and make the float parallel with the body.
Did you replace the float valves and valve seats? Sticky float valve will behave similarly.
I have found you can check the operation of your float valves by blowing thru the inlet. Carb rightside up should be very little resistance, upside down no air should pass. Drain the bowls first. Premix is an acquired taste.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
  #6
Old March 27th, 2008, 12:02 PM
Thanks guys for the input... I'm going to readjust the floats again today and see if that works. I'll let everyone know what the outcome is later on this evening.
Thanks,
Jeff
  #7
Old March 27th, 2008, 12:24 PM
of course manually using the primer soleniod will kill it by flooding. did it start right back up. did you check spark on all three, when it died?
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1990 Evinrude 200 VRO stalls when put in gear cwill Johnson & Evinrude Outboards 3 November 10th, 2007 07:38 AM
1990 Evinrude 60 HP Stalls 18RTO Johnson & Evinrude Outboards 2 February 14th, 2006 08:34 AM
1990 60hp Evinrude stalls GaryH Johnson & Evinrude Outboards 2 June 10th, 2005 12:45 PM
1976 70HP Evinrude Stalls brodmanns5 Johnson & Evinrude Outboards 2 June 19th, 2002 05:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
