  #1
Old March 26th, 2008, 01:52 PM
dimock44 dimock44 is offline
Unhappy Help with Lower unit 1991 Evinrude TE60TLEIB
1991 Evinrude TE60TLEIB I got late last year and it pumped water fine. I decided to replace the impeller before putting it back in the water.
#1 Problem
All of the bolts were very tight so I applied heat and when they came out it looks as though they had lock tight or some other kind of sealer so naturally 1 of them snapped off.
#2 Problem
The lower unit won't separate. I suspect a sealer of some sort was used here also.
Has anyone else had any similar problems and would share some solutions or just general advice as what to do next.
Thanks in advance for any and all comments.
Tom
  #2
Old March 26th, 2008, 02:12 PM
ezeke ezeke is offline
Default Re: Help with Lower unit 1991 Evinrude TE60TLEIB
Some mechanics seal the gearcase mating edge with Gel Seal or similar coating. You will have to break it loose.
The broken screw may be holding as well. They usually corrode on the shoulder rather than the threaded part so you may have enough left to put a visegrip on after heating it a bit.
There are seven bolts to remove holding the gearcase to the midsection if you include the one holding the trim tab; did you get them all?
  #3
Old March 26th, 2008, 02:18 PM
No Only six The last one only appeared to hold the lead. MY Bad. I will remove it and try again.
Thanks Ezeke
  #4
Old March 26th, 2008, 02:22 PM
The anode bolt is not one of them- that would make 8. Look above the trim tab and you will find one hidden there.
Good time to install a new anode though; it will help stop the corrosion of your bolts.
  #5
Old March 26th, 2008, 03:07 PM
Thanks Ezeke
Now where does the shift linkage disconnect. My manual goes through 1991 but on shows early model diagrams. also the anode show no deterioration. Does it still need replacing?
  #6
Old March 26th, 2008, 03:49 PM
Test your anode with an ohmmeter. It must have a solid connection. I looked at a guy's badly deteriorated lower unit last summer; he still had the plastic floor model fake anode in place and it looked great. Been there since 1982!
Your shift rod enters the engine compartment exactly centered between the port and starboard sides and under the rear of the carburetors, whereit attaches to a lever that moves it up and down. The lever is released by removing pin or clip and pulling the rod to starboard, I think, but am not sure..
  #7
Old March 27th, 2008, 05:24 PM
linge101 linge101 is offline
I have an Evinrude 150KP 1990 that I put a waterpump in. If your motor is like mine, you will need a very long pair of needle nose pliars to get the pin out of the shift fork. Good luck.
  #8
Old March 30th, 2008, 11:35 AM
Well the worst had to happen. One bolt snapped off and then the ez out broke off. Anyone had any luck with removing a broken ez out? Are there any dead 1991 rude 60 hp for parts? Does any one know what years are interchangable? I am almost afraid to look at a new section from BRP
Thanks in advace for any help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1991 Evinrude 175 hp Lower Unit ????? sportcraft17 Johnson & Evinrude Outboards 10 July 11th, 2007 04:27 PM
150 1991 force lower unit force 150 fl Force & Chrysler Outboards 1 June 30th, 2006 05:08 AM
1991 150 lower unit cowboyup Johnson & Evinrude Outboards 0 September 6th, 2004 01:34 PM
1991 150 evinrude lower unit ronuncw Johnson & Evinrude Outboards 7 September 3rd, 2004 01:08 PM
1991 Force 120 lower unit cinder1995 Force & Chrysler Outboards 3 June 9th, 2003 06:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
