  #1
Old March 25th, 2008, 06:27 PM
MuscleOnTheRidge MuscleOnTheRidge is offline
Question Mercury 40 Classic (Mystery water leak)
Hey guys, Can you help me? I have a 1992 40hp Mercury Classic and noticed a small water leak while tank running it a couple days ago. Right next to the the top spark plug is a very small hex head plug or screw that has developed a very small trickle of water. It looks like it goes right into the cylinder, but that can't be. Any clues as to what this plug is, and what is the best course of action? The motor serial is: OC233564
Thanks for any advice.
MOTR
"Introduce your kids to the outdoors, and they will have a friend for life!"
  #2
Old March 25th, 2008, 06:44 PM
Post Re: Mercury 40 Classic (Mystery water leak)
One of my buds explained that it is just a small plug and the leak is caused from a worn out gasket. He suggested pulling off the back plate to access and replace the $20 gasket. What problems should I anticipate when removing that cover from the motor? Help please.
MOTR
  #3
Old March 25th, 2008, 07:02 PM
Laddies Laddies is offline
Default Re: Mercury 40 Classic (Mystery water leak)
He is right it's the water jacket gasket leaking, just use care then removing the cover bolts they do break some times
  #4
Old March 26th, 2008, 01:18 AM
TriadSteeler TriadSteeler is offline
Laddies is so correct. I broke 4 of them and finding the correct bolts is not the easiest thing in the world. (Finally found them at a Fastenall about 1/2 mile from my house). I didn't take any chances and replaced them all.
I don't know if the 1992 is the same as a '74 merc 500 but the bolts on mine had nuts on the other end that were held in place with ridges coming up from the casting. Getting these things started proved to be quite the challenge. Especially the ones at the bottom. Get yourself one of those telescoping magnets. Trust me it will come in handy to find the nut you dropped that you can't see. Also it helps to hold the bottom ones in place while you get the bolt threaded in.
After you get the cover off you will need to completely clean all old gasket material off of the surfaces. This is tough because the aluminum is very easy to score using most traditional techniques. Look at some solvents to dissolve the gasket.
When reassembling you must use a torque wrench and I think that model requires 180 inch pounds (Laddies correct me if I am wrong. I'm guessing that his 92 Classic with that Serial is an American 4-cyl.) If you don't have a torque wrench to get that low, Hopefully you have a buddy who has a torque wrench you can borrow. The ones at AutoZone will not work. They are all in ft/lbs and can't get that low. I happened to order one off of Harbor Freight for 19.99. NAPA had them via special order for 258.00. Make sure you test the torque wrench to make sure it clicks at the desired torque on some other bolt before you start cranking away on the aluminum case. Cracking that thing would be disastrous. The bolts also need to be torqued in their proper order and be done at 1/3 the torque value each time i.e. 60 on all - then 120 on all- then 180 on all. I don't have the torquing order diagram with me right now, but I will post it tomorrow.
  #5
Old March 26th, 2008, 10:22 AM
Thanks for all the great information. I will take all of the advice, and heed your warnings on the cover bolts. Luckily for me, Fastenal is based here in town (Winona, MN) and they have an outlet store a few blocks away. The torque diagram would be a great help. Thanks again.
MOTR
  #6
Old March 26th, 2008, 10:35 AM
Question Re: Mercury 40 Classic (Mystery water leak)
Very hesitant to throw this suggestion out there, because I don't want to get mauled. Just how critical is this leak? Like I described earlier, it is that very small hex head port or plug that is less than an inch from the spark plug #1 port. It is a little more than a drip, but I am not sure how it is affecting the engine performance, nor do I know what might happen if left unchecked. I know you guys are not about short cuts, but just some objective advice on the severity would help. Is there a way to seal it externally without removing the cover?
MOTR
  #7
Old March 26th, 2008, 11:02 PM
I can understand your reluctance. Taking bolts out of your powerhead isn't exactly trivial.
However, Water is the universal solvent. It has a unique way of finding its way into small crevices fairly easily. Over time that drip will accumulate and work its way around your spark plugs and foul them out. The void in the gasket has the potential to continue to get larger. Then the water will continue to wind its way down the threads of the plugs. The blunt end of that spark plug is millimeters away from your pistons 1000-4000 times a minute. Pistons, rods, rings, cylinder walls and bearings are like cats. They hate water. It is a much easier job to take the water jacket cover than the crankcase cover. A $20 gasket and two days worth of labor is cheap insurance.
The option is always available to attempt a quick fix and patch it with RTV or some other sealant, but in the boating world a quick fix more often than not results in a major expense.
Oh, and here is the torque sequence for the water jacket bolts.
  #8
Old March 27th, 2008, 01:47 PM
Thumbs up Re: Mercury 40 Classic (Mystery water leak)
Thanks for putting it out there straight. I will round up a torque wrench and get this project done! Thanks for the diagram as well.
I really appreciate the help.
MOTR
  #9
Old March 27th, 2008, 10:21 PM
CharlieB CharlieB is online now
Before you start taking this thing apart, take a closer look at that 'plug'.
If that is a small pipe plug into the water jacket simply recoat the threads with liquid teflon to seal the threads and be done with it.
  #10
Old May 15th, 2008, 02:51 PM
Thanks Charlie.. I will check on that. It looks like a small hex head screw to be honest, and it is a very low profile head so it might be tough to get a tool on. Thanks again for the advice.
MOTR
  #11
Old July 5th, 2008, 08:02 PM
oldtruckface oldtruckface is offline
different motor but sounds like water pressure fitting location
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mystery omc oil leak please help me crownline250 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 March 14th, 2008 03:53 PM
Mercury Kf-5 "super 5" Mystery Gas Leak DDM71 Mercury & Mariner Outboards 0 June 20th, 2007 10:52 PM
Classic 50 mystery lakertaker Mercury & Mariner Outboards 2 June 8th, 2007 08:43 PM
oil leak mystery handball Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 November 5th, 2004 02:41 AM
Merc. classic fifty - mystery hole klausdk Mercury & Mariner Outboards 1 July 30th, 2004 10:01 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
