  #1
Old March 25th, 2008, 04:53 PM
gearyg gearyg is offline
Default 2002 Yamaha 4-Stroke 115hp Voltage Regulator?
Hello everyone, I will try to describe this the best I can. While on the water, I faintly smell at times kind of a rubber buring typ smell (similar to a loose belt on the car that keeps slipping). However, I removed the cover, but could not smell anyting out of the ordinary. I did some research and I was told that the only thing that it may be is the Voltage Regulator going bad.
I don't have a guage on my dash, so how can I test this? Can I put a meeter on the battery, start the engine and if it is working properly, should the meeter read a higher volt?
Any input would be appreciated...thanks.
  #2
Old March 25th, 2008, 07:21 PM
Yamajoe's Avatar
Yamajoe Yamajoe is offline
Default Re: 2002 Yamaha 4-Stroke 115hp Voltage Regulator?
Charge system output: Connect a voltmeter + to the + battery posts and - to engine ground. check reading. start the motor with both test leads connected;
voltage reading equal to or less than first measurement indicates problem with charging system. Volts reading more than 14v indicates overcharging both will require more checks of the system.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha 100hp, 4 stroke, 2002 rectifier/regulator Susan Garcia Yamaha & Suzuki Outboards 9 February 23rd, 2008 03:16 PM
2002 Yamaha 4-stroke 115hp DMBullock Yamaha & Suzuki Outboards 3 November 9th, 2007 08:20 PM
2002 Yamaha 115hp - # of Poles for new Tach? cigar_stub Yamaha & Suzuki Outboards 2 August 10th, 2007 09:05 AM
03 50 horse Mercury 4 stroke voltage regulator melted down mikerino Mercury & Mariner Outboards 6 June 28th, 2007 10:26 AM
Voltage regulator/rectifier Mariner 115HP bbalcer Mercury & Mariner Outboards 3 November 14th, 2004 12:43 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
