  #1
Old March 25th, 2008, 02:12 PM
Mokie Mokie is offline
Default Yamaha Multifunction Gauge installation
I need help installing a Yamaha Multifunction Tach. I have an '03 Yamaha 115 hp 4 stroke. The gauge came with a harness with two plugs that run back to the motor, and I believe 4 or 5 wires that run to the inition switch. So far I have only been able to locate one plug coming off the motor, and I believe it only has two wires going into it from the motor - the wiring harness has 4 wires in each plug. Couple of folks I talked to at Yamaha said that my motor should have both plugs, but I can only find one, I even pulled the boat over to the nearest Yamaha dealer and they were also unable to locate the other plug. I checked a newer motor, 07 I believe, and it had two plugs coming off the motor. Some people have told me that newer motors only have 1 plug, but that clearly is not the case. My plan now is to hook up what wires I can without pulling the harness through the hull, and see what functions I get on the tach. Several people said I should get RPM from the ignition connection, is that true? I was really hoping to get the trim function to work. Unfortunately I don't have all the part numbers from the motor and the gauge in front of me, but I'll be happy to supply if someone needs them to answer my questions.
Thanks for any assistance.
  #2
Old March 25th, 2008, 06:52 PM
rodbolt rodbolt is offline
Default Re: Yamaha Multifunction Gauge installation
the engine should have 2, one is alarm the other trim, in 05 they went to one.
but without looking I cant tell. on the engine 4 plug, what are the wire colors?
on your tach the yellow is 12v +, black is ground,blue is lights green is tach send. the pigtals are one the ign switch assy for 704 and flush mount controls and hanging from the box on 703 side mount.
  #3
Old March 27th, 2008, 08:58 AM
Thanks for the response. On the only square 4 way plug I can find coming off the motor, there are only two wires going into it from the motor. One is Pink/white and the other is pink/black. It is a female plug. On the male side running to the console is a black wire, a pink wire, and a brown wire that is capped off before it goes anywhere.
There is another plug right next to this four way which is round and has eight wires coming out of it.
I took a picture of it which I could send but I don't know how to attach.
The kit I ordered was 6YRWOO35E000
The tachometer was 6Y58350T8200
The trim/oil harness was 68F82553700
The gauge harness was 6Y5835532000
As I am looking through the paperwork that came with the kit I notice that what they sent me was:
Kit 6YRW0035E100 (which says for 2005+) mine is an 03
Tach 6Y58350T82BK
Extention wire lead (8M) 68F825539000
Wire harness 6R8825820000
Gauge harness 6Y583553N000
Maybe I just need a different harness? Any thoughts?
  #4
Old May 11th, 2008, 11:01 AM
r1cook r1cook is offline
Well it appears we have similar problems. The unit I received seems to be for pre 2005. The harness has two plugins and 4 wires. My Yamaha 40 is 2008 and it has only one plugin and two wires.
How did you resolve your issue?
  #5
Old May 11th, 2008, 11:39 AM
in 05 yamaha changed from two plugs on the engine to one, however the harness between the engine and console remains unchanged. so one gets capped.
we really really need a picture , occasionally when dealing with late style guages and pre 05 motors it requires an adapter at the engine side of the harness.
  #6
Old May 11th, 2008, 04:00 PM
Pictures are not problem.
So here is what I have. Pics are at this site.
http://picasaweb.google.com/pressure...iringHa rness
2 plugs on back of guage,
One has four wires, pink,, black, grey orange and it matches a plugin on harenss exactly.
One has two wires green and green with red stripe
Harness has two connectors on both ends with four wires in each. Pictures show it well.
I tried the connections putting them where they matched wire color and / or plugins fit. The gauge seems to do its prestart test fine and if I start engine tach works fine. Only thing acting funny is trim it, pegs out at five and flashes but never changes no matter where I put it.
Any help with this would be great!!
  #7
Old May 11th, 2008, 04:18 PM
TheFin's Avatar
TheFin TheFin is offline
Thumbs up Re: Yamaha Multifunction Gauge installation
Take a look at those DIP switches.
Here are the settings.
  #8
Old May 11th, 2008, 07:24 PM
r1cook
double check your dip switch settings on the tach as per thefins thumbnail.
the other issue in this hijacked thread I still need pics of but its my bet he will need the engine adapter for the pre 05 to post 05 engines, its in both the 05 tech guide and the rigging guide.
  #9
Old May 11th, 2008, 09:59 PM
  #10
Old May 11th, 2008, 10:07 PM
Thanks --and sorry for high jacking!! Three hours standing on my head wiring in this baby made me light headed and desparate!! Actually thought blending them together would bring in more info to help both the originator and myself.
Dips are fine but the adapter thing is interesting--off to the dealer!!
  #11
Old May 30th, 2008, 06:45 PM
I'm sorry I gave you the wrong information. After reading post again I realized we were talking about 2 different part numbers and I called Yamaha to confirm.
6Y5-85335-00-00 is to make older gauges(1994-2004) work on 2005 and newer motors.
6Y5-85335-10-00 is to make newer gauges(6YR-W0035-E2-00 and 6YR-W0035-F2-00 kits) work on older 1994-2004 motors. It connectes between Trim/Oil harness and gauges at console.
  #12
Old July 16th, 2008, 10:54 PM
danny223 danny223 is offline
Wrong place.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1992 Yamaha Multifunction Gauge power ybmug2 Yamaha & Suzuki Outboards 4 March 27th, 2008 08:49 AM
Yamaha multifunction gauge lights gr8rg8r Yamaha & Suzuki Outboards 1 May 6th, 2005 08:08 PM
Need Yamaha Multifunction Gauge Diagram JRC1490 Electrics, Electronics and Trolling Motors 0 July 1st, 2004 04:08 PM
Yamaha LCD multifunction Gauge Repair Prism Yamaha & Suzuki Outboards 10 January 4th, 2003 01:45 PM
Yamaha digital multifunction gauge TD Yamaha & Suzuki Outboards 4 December 14th, 2001 01:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
