1983-84 Johnson 40hp pops or misses and run away and no idle
tricky1000
I have a 83-84 VRO 40hp johnson that cranks ok idles with a popping or missing when you rev it up it it will not pop also I see a little fuel leaking out of the electric choke solinoid. It also after reving it stays at a really high idle and will no return. Then it will runaway after switch is turned off and fuel pulled. Any ideas?:confused:
tashasdaddy
Re: 1983-84 Johnson 40hp pops or misses and run away and no idle
welcome. sounds like you need to replace the primer solenoid. watch ebay for one. either that or you timing is off.
