  #1
Old March 25th, 2008, 12:14 AM
The Rock The Rock is offline
Default 1992 Evinrude 60hp Carb Core Plugs?
I have a 1992 Evinrude 60hp engine that I have been working on. The carbs were gunked up from sitting a few months. I decided to pull them and give them a good cleaning. I didn't purchase a complete rebuild kit since the everything was fairly new already and the only local shop wanted $28 per kit! I was able to purchase the gaskets seperately for $5 and I am replacing all the fuel lines. The problem is the guy that rebuilt this engine last time, didn't put core plugs in the carbs. He used some sort of compound/sealer that is orange in color and hard. When I was soaking the carbs I tried not to expose those areas to the solvent. Well, it loosened some of them anyway and I've got a delima as to what to do next. I know what I should do is remove the compound and install the plugs. Even the shot plug is covered with it. As far as I know, the only way to get them is in the rebuild kits. Does anyone know what the previous mechanic used, or why other than being cheap? He has been working on the motors for 50 yrs. I was told at the parts store that in order to install the core plug, you need a "special tool", that usually means spending alot of $$ for something I won't ever use again. I know I can get the kits cheaper on the net just about anywhere, but was trying to avoid the extra cost and downtime. I would have to get 3 of them since all 3 carbs are this way. Any advice would be helpful.
Thanks,
Rocky
  #2
Old March 25th, 2008, 09:29 AM
wavrider wavrider is offline
Default Re: 1992 Evinrude 60hp Carb Core Plugs?
Get the kits and install the correct plug.
that way you will not get stranded on the water due to some junk floating in the carbs.
They are not hard to install, I believe some people just tap them in the center and this flattens the plug out giving a good snug fit to the core.
Removal, some members have mentioned they drill a small hole in the center and remove them with a scribe or bent hook type tool.
  #3
Old March 25th, 2008, 09:35 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
i use a small ice pick, and just punch thru and pry them out, i use a short piece of 1/4" wood dowel to tap them in.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old March 25th, 2008, 09:39 AM
Dhadley Dhadley is online now
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
The orange sealer is probably Gasoila (sp?). That's the correct sealer.
  #5
Old March 25th, 2008, 11:15 AM
Is the only way to get new core plugs from the kit itself, or does someone know where I could get them seperately? I haven't taken off any of the sealant yet, for all I know there may be plugs installed and he put that stuff on over the top of them for some reason. After I cleaned the carb and blew out everything with compressed air I noticed fluid being forced out of one of the core plugs thru the cracks in the sealant. Is the core plug supposed seal the hole and prevent fluids from escaping? Since it is metal on metal with no gasket involved, I wouldn't think it would make a good seal? Thanks for the advise so far. I hate the thought of spending $60 on 3 kits for some plugs!
Rocky
  #6
Old March 25th, 2008, 11:23 AM
Quote:
You spelled it correctly, and that does appear to be what it is. Should this be applied over the core plugs?
  #7
Old March 25th, 2008, 11:27 AM
they are suppose to seal. sorry. he may have used old plugs.
__________________
FLORIDA GATORS
TEBOW Country
  #8
Old March 25th, 2008, 02:42 PM
iwombat's Avatar
iwombat iwombat is offline
You can buy core plugs separate. Look up the part number at the brp site. I got a few from sea-way last time I went in. They're about $1 each.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
carb core plugs, how to remove? Zep-- Johnson & Evinrude Outboards 4 August 27th, 2006 05:07 PM
1992 Evinrude 60hp tach problem trucky9754 Johnson & Evinrude Outboards 2 April 11th, 2006 12:19 AM
Carburettor core plugs rudeafrican Other Outboard Brands 4 April 11th, 2003 07:43 PM
1992 60hp Evinrude Starter. Quin Johnson & Evinrude Outboards 6 September 19th, 2001 06:23 PM
1992 60hp Evinrude Quin Johnson & Evinrude Outboards 3 August 7th, 2001 05:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
