  #1
Old March 24th, 2008, 07:22 PM
adrunkntoddy adrunkntoddy is offline
Default Need help with my Mariner power tilt assembly
New to the forum, I like it so far!!
1993 Mariner 115 4 cyl. with 2 wires and a single piston.
My trim motor is very slow. So I took the engine off the boat and took off the power tilt assembly. The motor seemed to be ok, but there was water in the fluid. So... I want to make sure the valve body is put together correctly (I bought the whole mariner used). Does anyone have a diagram of the valve body? Like where the check balls go and springs and orings and so on... I have a diagram, but it is not specific for the valve body.
thanks fam,,
regards
ToDDR
  #2
Old March 25th, 2008, 02:12 PM
Default Re: Need help with my Mariner power tilt assembly
bump
  #3
Old March 25th, 2008, 03:20 PM
Seasprite175's Avatar
Seasprite175 Seasprite175 is offline
My trim motor is also very slow on my 92 115. I have not taken it apart yet, but I have a seloc service manual that says the pump is not serviceable and must be replaced as an assembly. It doesn't give any diagram of it.
  #4
Old March 25th, 2008, 06:45 PM
thanks for looking,,
anyone else had this problem?
  #5
Old April 2nd, 2008, 11:19 PM
over indulgence over indulgence is offline
sure its not the o-rings? look at the one thats around the piston (does it have a flat spot, cracks, or nicks?) and the in the upper cap. you cant get these rings anymore from mercury but i have found the aftermarket ones (for these 2 only). i repalced mine due to leaking and so far so good. ill have to check on the numbers and supplier(i got them from an oil field supply co. just take in what u got and they can match or order). if ud like you can reach me at kbrown67045@yahoo.com.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mariner 75 power tilt and trim stuck burney Mercury & Mariner Outboards 1 May 26th, 2007 05:56 PM
Mariner 60HP power tilt problem joed Mercury & Mariner Outboards 2 June 4th, 2005 06:39 AM
OMC Power Tilt Assembly Schematic fritz58201 Johnson & Evinrude Outboards 1 April 13th, 2005 09:01 PM
HELP!!! Mariner 150 Power tilt and trim gchapman Mercury & Mariner Outboards 2 May 13th, 2004 01:36 AM
seal kits for johnson power tilt assembly feed_me57 Johnson & Evinrude Outboards 1 February 18th, 2004 02:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
