merc. upper steering shaft.
stroyer
Hi, from Denmark
I have a 1990 Century 270 xl with a Mercruiser 350 magnum and a Alpha One sterndrive. I have appr. 4 inches sloop in my steering.
Does anyone know what year merc started using the square to square upper steering shaft in the gimbal ring, in stead of the square to spline ?
And what is the easiest way to replace the axel and the steering arm ?
Re: merc. upper steering shaft.
Ayuh,...... Long before your 1990.......
Pull the Drive,.... Then the motor, then the transom assembley,....
Repair it,+ Reinstall Everything......
Haut Medoc
Did you try tightening the two bolts on top of the gimabal ring?...:confused:
I'm pretty sure that the newer design by 1990......
If it needs replacement, not an easy fix, is it a Gen 1 or Gen II?....:confused:
Probably Gen I from that year, but it is close enough to the change, to verify....
stroyer
It is a gen I
What about the method where you drill holes above the axel or the steering shaft ? Is that not durable?
the two bolts are tight.
so i need the square to square axle ?
Haut Medoc
Page seven, section four covers that.....:)
I would makes sure I have isolated the play before teardown....;)
stroyer
the play is between the upper steering axle an the steering arm. not in the gimbal ring.
i had to find out what type axle there is in my transum, square or spline.
it looks like it is a square to square axle in my Alpha One gen. 1 from about 1990.
what about this method ?
http://www.mercstuff.com/gimbalringinst.htm
That method works just Fine,....
But only if the tiller arm Only needs to be Tightened.....
To Replace it,..... Ya gotta take it Appart.......
stroyer
OK...
i did not know that.
i thought that i could replace the axle by loosen the bolts thrugh the holes.
my bad....so i gotta take it Appart.......
thanks for the help.
Haut Medoc
Good deal!......:)
Keep an eye on all of those bolts at least once a year....;)
stroyer
Good deal!......:)
I will.. and i secure them with Loctite.
By the way it was a square to square axle.
Haut Medoc
I would not put loctite there as it generally needs heat to release....;)
Just keep an eye on them.....:)
stroyer
OK.
I just keep two eyes on them.:eek:
