Convert an 87 V-4 140 Evinrude from 9amp to 35 amp charging
greenbean
I was told that it is possible to change the charging system on an 87 140 V4 Evinrude from 9amp to 35amp. Does anyone know what would be involved as far as what I would have to change on the motor.
Thanks in advance,
Dhadley
Re: Convert an 87 V-4 140 Evinrude from 9amp to 35 amp charging
Yep, no biggie really. You'll need parts from a V4 looper Sea Drive powerhead. Flywheel, stator, upper main bearing housing and rectifier / regulator.
greenbean
Thanks for the reply, I really appreciate the help.
Greenbean
Dhadley
Anytime. If you need anything else just let me know.
