I have a 40hp Japanese built mariner. During rebuilding the lower carb, the primer jet screw broke apart and is now stuck inside. Also the drain screw broke off and is also now stuck. I tried a screw extracter on the drain srew and the extractor bit broke off inside the drain screw. the drain screw now leaks. Any idea how to get these pieces out without damaging the housing?
