Go Back   iboats Boating Forums > Boat Restoration and Building > Boat Restoration and Building
Reply
Thread Tools Search this Thread Display Modes
  #1
Old March 23rd, 2008, 08:40 PM
KewlBird's Avatar
KewlBird KewlBird is offline
Default Replacing floor on Aluminum boat, suggestions on wood...
Hi, I am in a process of redoing the interior of my new boat (1985 16' Starcraft). I will be replacing the floor since it feels a bit soft. I'm trying to figure out what kind of wood to use to replace it with. I've read a post that treated plywood may affect aluminum. So, can I just use standard plywood from Home Depot (there are two types: BC and CDX, BC being sanded and more expensive), then cover it with deckseal or polyurethane? Thanks.
  #2
Old March 23rd, 2008, 08:48 PM
drewmitch44's Avatar
drewmitch44 drewmitch44 is offline
Default Re: Replacing floor on Aluminum boat, suggestions on wood...
Use whatever has the most ply's from HD or lowes. As long as you glass it its ok!
  #3
Old March 23rd, 2008, 08:49 PM
Im going to use stuff that is 1/2 inches and is 5 ply. Its up to you though a lot of others would go with 3/4 but i want to save weight.
  #4
Old March 23rd, 2008, 08:53 PM
KewlBird's Avatar
Quote:
My original is 1/2 inch so I'll stick with it, so resin by itself is the way to go?
  #5
Old March 24th, 2008, 12:40 AM
flounderman flounderman is offline
Gluvit is good. I have used polyester resin also. What will your final surface be, carpet , vinyl or maybe TUFFCOAT ?
  #6
Old March 24th, 2008, 01:48 AM
oops!'s Avatar
oops! oops! is offline
stay away from water seal or water proffing products...resin and glass will do just fine....seal it all even the sides of the ply
  #7
Old March 24th, 2008, 07:40 AM
KewlBird's Avatar
Quote:
Final surface will be carpet.
  #8
Old March 24th, 2008, 08:24 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
i use 5ply 1/2 inch exterior, home depot and lowes may not carry it. standard 1/2 is 3 ply.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #9
Old March 24th, 2008, 08:40 AM
KewlBird's Avatar
Quote:
The BC ply from Home Depot is 4-ply, however I'm not sure it's exterior grade. The CDX ply I don't know how many ply's it has but it is used for roofs and etc., however it looks very rough with many more voids. You think I'm safe going with the BC? And do I need to use fiberglass mat, if so what weight should I go with? By Friday night the old floor will be out, and hopefully the new one goes in on Saturday. I'm almost done with the teardown only about 15 screws away from having everything out of the boat except the floor. Thanks.
edit: Found the answer on the plywood. The BC plywood is made with exterior glue, so I'll go with it. This website has some good answers about differences in plywood - http://www.capitolcitylumber.com/plywood.cfm
Last edited by KewlBird : March 24th, 2008 at 11:28 AM. Reason: Answered part of my own question :)
  #10
Old March 26th, 2008, 05:26 PM
TonyD20 TonyD20 is offline
I did the same thing to my 16' Starcraft - 1/2" Plywood and use Resin to seal it.. sides and all.... make sure you do it outside .. let dry real good..
  #11
Old March 28th, 2008, 01:31 PM
GregE GregE is offline
Any idea if TUFFCOAT adheres to epoxy-sealed wood? I know it's adheres to wood, but that may be uncoated, bare wood. Any idea?
  #12
Old March 28th, 2008, 02:03 PM
tuff coat--
KEY FEATURES:
* Water Based
* No VOC's
* Single Component (no mixing)
* 19 Standard Colors
* Chemical Resistant
* Salt Resistant
* Highly Durable
* Rubberized (made of recycled rubber)
ADHERES TO:
* Metal
* Concrete
* Painted Surfaces
* Aluminum
* Fiberglass
* Wood
* Primers
__________________
FLORIDA GATORS
TEBOW Country
  #13
Old March 28th, 2008, 11:38 PM
Yea I saw that. I'm gonna email them but from that list one can possibly assume epoxy fits into the primer category. I guess the main thing with any coating is scuffing the surface pretty decent first. I know you've done tons of boat restoration. What's a good grit of sandpaper for pre-paint scuffing of epoxied wood?
  #14
Old March 29th, 2008, 09:23 PM
KewlBird's Avatar
Progress has been made...pictures to follow. The floor is all cut and covered in resin, just about every other piece is cut and painted/resined. The yellow foam in the boat is kind of wet, previous owner didn't have the boat covered. You can see wetness in the closeup of the picture of the foam. The foam is drying (the whole thing was wet), the only spots that are still wet are under the splashwell. I plan on leaving it without a floor for couple of days so foam gets a chance to dry out. There were also a few rivets that popped (see closeup), I put in new ones.
One piece is kind of worrying me, the piece that goes under the floor in the bilge. I wasn't sure how it would bend into place when covered in resin, so I attached the side holders and covered the bottom with resin (I know I missed a spot). I plan on putting it in place then covering the top in resin. I just hope it doesn't crack now that resin is hardened....
  #15
Old March 29th, 2008, 09:24 PM
KewlBird's Avatar
  #16
Old March 29th, 2008, 09:37 PM
gunner1's Avatar
gunner1 gunner1 is offline
Can you post a pic of the type of resin you used?
__________________
Visit my project page. http://www.shareaproject.com/pages/p...,p,416,00.html
  #17
Old March 29th, 2008, 10:14 PM
KewlBird's Avatar
I used "Boat Yard" brand from Ace Hardware. Cheapest I found... http://www.acehardware.com/product/i...entPage=family
  #18
Old March 29th, 2008, 10:49 PM
gunner1's Avatar
Quote:
Did they have that "in store" or did you just order it? Did you just apply straight from the can and let dry? Why type of coverage did you get per gallon?
__________________
  #19
Old March 30th, 2008, 07:32 AM
KewlBird's Avatar
Quote:
I bought it instore, it's $34 instore where I'm at. It comes with a hardener, so you'll mix a batch at a time. If you follow the directions you'll only have about 10-15 minutes to use up whatever you mixed up, so mix a little at a time. It covered both sides of what you see in the pictures, and I still have some left over.
  #20
Old March 30th, 2008, 11:01 AM
nice work, should be great.
__________________
FLORIDA GATORS
TEBOW Country
  #21
Old March 30th, 2008, 12:18 PM
Looks great Kewlbird. Did you use resin without laying down any cloth?
With all the reading I've done on this board over the last few months, I'm confused on something. (yea, there's a shocker ) If not using cloth, wouldn't epoxy would be the way to go? I thought fiberglass resin wasn't preferred when using as a direct coating if cloth wasn't being used.
Can someone set me straight? I'm viewing from the same prospective use. Wood in an aluminum boat for decking/floor. Covering the wood with resin (fiberglass or epoxy??) which is then covered with carpet, vinyl, nonskid paint, etc.
  #22
Old March 30th, 2008, 12:42 PM
Greg, Yes its better to use matt or even cloth with the resin. But i have found that if you dont go crazy with the resin it dosent get brittle when you dont use any mat or cloth. If you put on thick layers of the resin itself then its pretty weak and can break easily. If it is a pretty thin layer than it should be ok in my opinion. Its not like he is building a 40' offshore boat so he should be fine with what he has done. It is most likely beter than it was when it was new from the manufac.
  #23
Old March 31st, 2008, 09:29 PM
Great, thanks for the reply. So I'm not "totally" confused after all.
  #24
Old October 26th, 2008, 11:28 PM
CDN Fisher CDN Fisher is offline
This is fantastic. I am excited that I found this site as I am currently replacing the floor in my 1976 Aluminum Starcraft Supersport. I am using resin as it was recommended by a friend that renovated his floor using the same. Your pictures are great; makes me confident I am heading in the right direction. I will take some pics tomorrow and post them as soon as possible. Up here in the Canadian north, I am rushed a little by the dropping temps. Take care and best of luck. I look forward to seeing and reading more of your success.
  #25
Old October 26th, 2008, 11:31 PM
Just had to add a quick note. I saw that I am listed as a "cadet". I may actually be slightly lower in seaman's terms as I am a Canadian Air Force Officer (Tactical Helicopters); be gentle.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Replacing Floor in 1984 Lund 14" Aluminum taysburgh Boat Restoration and Building 2 June 12th, 2007 02:22 PM
Novice - some suggestions on replacing floor - see pics febod Boat Restoration and Building 26 September 5th, 2006 02:08 PM
replacing floor aluminum rivets beertech44 Boat Restoration and Building 9 March 28th, 2005 06:50 PM
Replacing wood seat/plywood, use aluminum? Heinz CA. Boat Topics and Questions (not engine topics) 1 January 31st, 2003 04:38 PM
replacing the wood floor on a 16ft tri-hull ginger Boat Topics and Questions (not engine topics) 1 May 7th, 2002 08:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
