  #1
Old March 23rd, 2008, 03:19 PM
danportr danportr is offline
Default Old Evinrude Sportsman motor
Hi All,
I was just given an old Evinrude sportsman motor. It's a tiny thing, caked with dry mud. The SN looks like 4425-103-3C? Anyone know what year model this is?
Thanks,
Dan
  #2
Old March 23rd, 2008, 04:28 PM
bassboy1's Avatar
bassboy1 bassboy1 is offline
Default Re: Old Evinrude Sportsman motor
1.5 horse motor made from 1948 to 1951.
__________________
http://www.shareaproject.com/pages/p...,p,482,00.html
Click above to view my 1542 jon boat project.
  #3
Old March 23rd, 2008, 05:36 PM
F_R F_R is offline
The "C" makes it a 1950-51.
  #4
Old March 23rd, 2008, 06:40 PM
tmcalavy tmcalavy is offline
Get it running...check compression, spark, fuel system for crud. Good little motors to dink around with and easy to maintain/run.
  #5
Old March 24th, 2008, 01:07 AM
Hey Guys,
Thanks so much. 1951, that's older than I am (barely)! It's got alot of mud in it but it looks really simple. I'll get it running. I got the choke working again and oiled all the fittings and screws. It will probably need a full overhaul but I need a new project as I just finished a dinghy (amesbury skiff from midwest models to full scale 10'). I would have replied sooner but my sister's birthday is tomorrow and we sailed San Francisco bay on my restored 1942 Bear boat (www.bearboats.com #24). Great sail, good winds.
Anyone know where I can get an exploded view of the motor or a manual? I can pay for it. Also, what's the fuel mix ratio?
Thanks again,
Dan Porter
  #6
Old March 24th, 2008, 07:53 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
outboardbooks.com possibly.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #7
Old March 24th, 2008, 09:31 AM
Fuel mix ratio is 16:1 when it was manufactured. If you're lucky it has the old style indestructible coil. If the coil is cracked it has the later style. Probaby just have to clean/regap points to get it sparking again. Check the LU grease, it doesn't use oil cause it may not have true seals in the LU...use Lubriplate 105 white grease. The carbs on those are real interesting...you have to readjust the rich/lean mixture as you increase throttle, a neat feature...they really purr along when you get it all right.
  #8
Old March 25th, 2008, 12:38 AM
Hey Guys,
I sent Ken Cook an email on 4425 in stock, I am presuming that is the model number. I haven't ordered yet until it's confirmed by them but will. Thanks alot for the mix and lube stats. This motor should run again. I am a machinist and will make the parts if I need to. I'm also an electronics tech and will wrap a new coil if that's what it takes. First I need to get the mud out as it's abrasive.
Thanks,
Dan Porter
  #9
Old April 5th, 2008, 11:38 PM
Hey Guys,
I got the new service manual today, cool! Last revision 1956, wow! Time to tear it apart.
Thanks,
Dan Porter
  #10
Old April 6th, 2008, 12:11 AM
jbjennings's Avatar
jbjennings jbjennings is offline
You're a machinest AND an electronics technician? Dang! I'm jealous. I wish I could make parts and figure out electronics.....That's one reason I like the old motors, because I don't like the new electronics stuff that are hard to figure out and more expensive to replace. I hope you post a pic of your old motor when you get it running. Old motors are even sweeter when someone gives it to you, huh!?
good luck,
JBJ
  #11
Old April 6th, 2008, 06:55 AM
no, they are sweeter, at the ramp or dock, when you give them one pull and they start, and purr, while everyone else who neglects there motors, are trying to get theres started.
__________________
FLORIDA GATORS
TEBOW Country
  #12
Old April 6th, 2008, 09:31 AM
wbeaton's Avatar
wbeaton wbeaton is offline
Quote:
I second that!
__________________
Wayne
  #13
Old April 11th, 2008, 09:16 PM
Hey Guys,
It started today! I tore the carburator apart with the data pages and replaced gaskets with hand cut gasket material, cleaned gobs of crud and spiderwebs out. The inner throttle butterfly was stuck, broke the arm off it trying to free it. Finally got it apart and machined a new key on the end to fit the arm and silver soldered it (jewelry grade hard solder). Everything went together according to the plan (thanks to outboardbooks.com and the tip that lead me there (tashasdaddy)).
Yesterday I tore into the motor, points looked ok and the coils (plastic) beeped out good. Couldn't get the flywheel off so took it to the local garage for a wheel puller, $5/5min., cool. Removed the timing plate and took the cylinder head off to check the piston and all. Cleaned everything with carb cleaner (strong stuff!). The paint came off the outer cylinder head, oh well, good paint remover. I used the same head gasket as it's harder grade than the paper stuff I got, seems OK though. I pulled the bottom gearbox off to get the grit out of the swivel, but the pump screws wouldn't budge. Drained a bunch of black tar out of the gear box, diluting with WD40 until it drained clean and replaced with 90 weight as per the manual (90 wt., not the WD40).
"If it moves and shouldn't use duck tape, if it doesn't move and should, use WD40." (anon)
So I put it all back together and dumped gas mix (5oz/gal) in the tank, put it in my makeshift water tank (2 ladders and an old mahogany plank plus a tank from the old cooler in the barn with a 1 hole stopper plugged with a drill bit). I opened up the fuel valve and gas came gushing out the valve, shut it off. Call it a day.
This morning I pulled the motor from the tank and laid it down, removed the fuel valve. The gasket seal was shreaded and falling apart. I cut a piece of leather to fit and put it back together, works fine.
Back at the tank I opened the valve and pulled a couple times and it STARTED!!! it only ran a couple seconds and died, but it's firing. I turned off the choke and tried again and it ran awhile and died. It would only run in the start position for a little while then die. I pulled the motor again and changed the throttle linkage to the outer hole and it worked better, but still dies out.
I think the problem may be dirty gas as I didn't flush the tank but that's next. Probably need to reclean the carb, oh well. But it runs!!
Thanks All,
Dan
PS. JBJ the new computer chips are still impossible to figure out. This old beast is cool. The motor was free but the manual ran $50, well worth it. It's a revised edition 1956, amazing they still have it.
  #14
Old April 11th, 2008, 10:29 PM
Yeah sounds like you need to clean the fuel system. Does it have a dual butterly carb, or the old gas mixing valve carb with the big RICH-LEAN needle on the front? Can't remember when they changed. If yours has the big single Rich-Lean needle/arm on the front, it has to be tweaked every time you speed up or down to find the sweet spot...you memorize them after awhile. Those are cool little motors. If there's a youngster in your family, be sure to share this with them...they love to tinker almost as much as us old f**ts.
  #15
Old April 11th, 2008, 11:24 PM
I dumped the gas and it has some black grit in it. Back through the carburator we go. The carb has 2 butterflies, one in front (choke) and one in back (throttle). There is a knob in front that reads off, run, and choke that connects to the needle valve and also has a linkage to the choke when the needle is wide open. The back throttle butterfly has a linkage that is pushed open as the timing is advanced (?) with the stop/slow/start/fast arm. There is also a slow idle screw needle above the knob. The book says adjust it to 3/4 turn out.
As it is now, I can only get it to run in the start position with the needle knob set to run. Faster or slower and it just conks out. Tweeking the slow idle also conks.
Inside at the gas inlet there is a copper float donut and a knotched arm that opens a needle and seat. In back there is a flat steel valve with a harder steel triangle stop that feeds the cylinder.
I'll go back into it tomorrow to clean the grit.
Thanks,
Dan
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude Sportsman Outboard Motor Slideless Johnson & Evinrude Outboards 5 February 18th, 2009 06:56 PM
evinrude sportsman rsmith032 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 June 14th, 2007 01:15 AM
Evinrude Sportsman yr and hp ? scwaters Non-Repair Outboard Discussions 3 May 14th, 2006 08:49 AM
OLD EVINRUDE SPORTSMAN IBSWAMPY Non-Repair Outboard Discussions 4 October 3rd, 2004 08:32 PM
evinrude sportsman dave bunner Johnson & Evinrude Outboards 3 May 13th, 2003 05:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
