  #1
Old March 21st, 2008, 10:24 PM
jayhawkokie jayhawkokie is offline
Default Evinrude Lark Electric Shift Question
Hi Folks,
This my first time on this forum. I am thinking about buying an older boat from a friend, the price is right and the boat is in great shape. It has a 50hp Evinrude Lark engine with electric shift.
My only concern is the electric shift. My friend said it has always worked fine until we took the boat out today. It didn't want to shift into neutral. When we idled the engine down and shifted it into neutral it would slip in and out of the forward gear without pushing the button and then it got where it wouldn't go into neutral at all.
Is there a simple fix, like cleaning the contact points on the push buttons. Should I back away from buying the boat because of potential future problems with the electric shift. Are parts still availible for this engine and the shift mechanism?
I like the boat and it's a steal. This will be my first boat and it will let me know if I really want to own a boat without investing a pot full of money.
Thanks for your help.
Jayhawkokie
Beautiful Grand Lake O' the Cherokees, Oklahoma
  #2
Old March 21st, 2008, 10:36 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Evinrude Lark Electric Shift Question
sorry back away, new parts are not available, for the shift solenoids, or the control. i would buy 1973 to 1977 is better, 1978 up is best.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old March 21st, 2008, 10:59 PM
freddyray21 freddyray21 is offline
many times the problem is in the shift box not the lower unit. However, as already mentioned parts are very hard to come by including the shift boxes.
  #4
Old March 21st, 2008, 11:02 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
You don't say what the model number of the engine is or the year. However, since it is a 50 hp, any electric shift would have to be the Hydro Electric Shift model.
Your problem could simply be that the lower unit has the wrong (HiVis) gear lube in it. That unit requires what is called Preminum Blend, also known as Type C, available only at your local Evinrude/Johnson dealership.
As Tash states, most parts are no longer available, and unless you can buy the boat at a fair price and have the engine thrown in as a bonus, it's probably best to walk away from it.
  #5
Old March 21st, 2008, 11:44 PM
samo_ott's Avatar
samo_ott samo_ott is offline
I know nothing about the hydro electric shifts but is it possible to convert them to a manual shift should you find an LU for it?
It would be fun to take one of them apart though to see what makes em tick...
__________________
Steve.
  #6
Old March 22nd, 2008, 09:27 AM
F_R F_R is offline
Too much fear of the Hydro-Electric shifts. The two major problems are lack of care (oil) and the push button switch. The switches are hard to find and expensive. You also can use a Johnson control. Their switches are also expensive, but don't seem to cause as much trouble.
If you are going to trash the motor, dump it in my front yard.
Samo, converting it to manual shift would require an act of Congress.
  #7
Old March 22nd, 2008, 09:31 AM
Thanks for the information. The engine model # is 50273C, I think it was manufactured in the late 70s. My friend inherited the boat from his Father in law, he's selling it to me for $800.00 if I decide to buy it.
It has always been well maintained and is clean as a pin. It's a 16' Kingfisher, comes with an almost new trolling motor and depthfinder/fish locator. If I thought it could be converted to manual shift in case the electric shift is crap I might go ahead and buy the boat. The engine runs like a clock otherwise.
He did have a problem with it shifting into reverse a couple years ago and the mechanic discovered he put in the wrong oil in the lower unit.
Jayhawkokie
Grove, OK
  #8
Old March 22nd, 2008, 09:41 AM
it a 1972 hydro-electric shift. it could just be a dirty corroded connection. if it is the switch, Joe has a way of making one with a toggle switch, but it does not have the neutral safety switch. but i came up with using a push button, that you have to push, before you start, that remind you to check that it is in neutral.
__________________
FLORIDA GATORS
TEBOW Country
  #9
Old March 22nd, 2008, 10:32 AM
patrick4266's Avatar
patrick4266 patrick4266 is offline
Send a message via Yahoo to patrick4266
I watch ebay and I see the electric shift conrol boxes quiet often, sometime with the wiring harness. I have a electric shift. I was able to get a spare engine, boat , trailor and controls for 300. I have done sold the trailor and just about got my money back. I kind of like the push buttons. It reminds me of a old 57 plymouth I had when I was a kid
__________________
1972-85 hp-rude
1970-85 hp-rude
1988 yamaha pro50
  #10
Old March 23rd, 2008, 11:54 AM
We're going to change the oil in the lower unit to make sure it has the right vis and see if that corrects the problem. The oil in the lower unit has been changed religously every year since the engine was new. It's basically a one owner engine, it was passed on to my friend a couple years ago. I haven't committed to buying the boat. If I do, I may need to get ahold of Joe to find out how he converts the unit to a toggle switch.
This is really a nice little boat and I feel the price is right, I just wish it had a different engine. I like to tinker and it would be fun to "explore" the electric shift.
Jayhawkokie
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude Electric Shift Question tex599 Johnson & Evinrude Outboards 8 February 6th, 2008 01:25 PM
evinrude 40 Lark selectronic shift 57whitehouse Johnson & Evinrude Outboards 10 August 1st, 2007 04:48 PM
Kill Switch? Evinrude Lark VI 40HP 1964 Electric Shift imported_Samuel Johnson & Evinrude Outboards 1 July 28th, 2006 10:11 AM
40 hp Lark electric shift lower unit AmigaDragon Johnson & Evinrude Outboards 1 August 15th, 2003 09:07 AM
'61 Evinrude Lark III 40 - Shift problem jpollman Johnson & Evinrude Outboards 13 March 27th, 2003 04:41 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
