  #1
Old March 21st, 2008, 08:11 AM
Zeph Zeph is offline
Default ignition resistor wire for Evinrude 60HP
Hey there, anyideas where to get resistor wire for an ignition? I have a 1967 Evinrude 60 HP Sportfour that I had to make a new motor wiring harness for, and need to locate the resistor wire. Thanks guys...........Zeph
  #2
Old March 21st, 2008, 10:29 PM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
Default Re: ignition resistor wire for Evinrude 60HP
Disconnect the red/white candy striped resistor wire and put an external resistor on the original omc (non resistor) coil...or...disconnect the resistor wire and install an automobile coil with internal resistor built into the coil. Run a standard wire in the resistor wire's place.
I did an auto coil with internal resistor on a 1965 75hp OMC and it worked fine. A trusted OMC dealer gave me that advice in 1985 when I bought an old classic glass boat with the motor. OMC coils were no longer available so I took the dealer advice. Auto condensors also work on the ignition.
bp
  #3
Old March 22nd, 2008, 07:31 PM
I'm curious what size resistor would be used?
  #4
Old March 22nd, 2008, 10:49 PM
Don't know resistor values but if any generic 12v auto coil works as a swap then logic tells me any generic ballast resistor for a 12v auto coil should work. They cost $7 at the auto parts store. A new auto coil with internal resistor only costs $25 and eliminates old dated coil woes.
bp
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
need help. 1971 60hp rude ignition. lost where a wire , pickup and coil question evinrudedude Johnson & Evinrude Outboards 0 May 1st, 2007 12:00 AM
do I have a resistor wire? snlgraham Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 24 June 14th, 2006 09:53 AM
Resistor wire john king Johnson & Evinrude Outboards 1 May 2nd, 2006 07:19 AM
Resistor Wire LuckyPenny Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 February 12th, 2006 04:09 PM
Looking for kill wire 1970 60hp Hydro-Elect on battery cdi style ignition kas Johnson & Evinrude Outboards 6 July 20th, 2003 08:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
