  #1
Old March 21st, 2008, 12:48 AM
billy7 billy7 is offline
Default Yamaha Fuel-flow Question
I've got a 1997 Yamaha C60 (two-stroke) and I'm thinking about installing a canister type fuel/water separator on it. Also, I've already got an in-line fuel filter on it. What I'm wondering is will having both the water separator and the in-line filter be too much restriction in the fuel line for the fuel pump to work properly? It has a vacuum operated pump. I don't want to risk starving the engine for fuel and end up burning out a piston.
Also, does anyone know if the water separators sold at Walmart are any good?
Any help on these issues would be greatly appreciated.
  #2
Old March 21st, 2008, 12:53 AM
edzzed's Avatar
edzzed edzzed is offline
Default Re: Yamaha Fuel-flow Question
if your boat is setup for it what about an electric fuel pump. Ed
  #3
Old March 21st, 2008, 08:40 AM
mpsyamaha mpsyamaha is offline
im not sure about the walmart water sep filter. might be alright, but i would stick with a nice racor. they are nice because you can see if there is water in them and empty it out.
as far as restrictions, adding a water sep filter shouldnt cause any problems.
  #4
Old March 21st, 2008, 10:22 AM
Thanks for the knowledge, guys.
While I'm sure that would remove all worry, I really don't want to get into all the expense and hassle of converting over to an electric fuel pump.
I'll check on a Racor.
  #5
Old March 21st, 2008, 04:07 PM
Silvertip Silvertip is offline
Electric fuel pumps on a non-ECM two stroke are very dangerous. Have a float hung up and the pump will pump a tank full of fuel into the engine if the key is inadvertently left on. Electric fuel pumps, whether on a car, truck, or boat need to have a automatic shut off installed so that if the engine quits the pump also quits. Unlike your car or truck which does that via the oil pressure switch and ECM, a two stroke has no way to perform that function unless its an ECM controlled unit. Lack of a tach pulse can shut the pump off but on a non-ecm two stroke you would need to fabricate that feature using the tach pulse or some sort of vacuum switch. Without an auto-shutoff feature, if a fire erupted on the vessel, the electric pump would feed that fire even though the engine may no longer be running. Do people do it? Yes! Is it safe? No!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
fuel flow question jcarey Yamaha & Suzuki Outboards 6 August 24th, 2007 08:04 PM
2001 Yamaha 90HP 2 stroke 90TLRZ - water flow question dpfundst Yamaha & Suzuki Outboards 1 May 1st, 2006 10:34 AM
Yamaha 225 Excel fuel Flow ( Help needed!) Bandaid Yamaha & Suzuki Outboards 6 February 5th, 2006 02:41 PM
Yamaha 55 fuel flow problem goof01698 Yamaha & Suzuki Outboards 2 July 22nd, 2005 01:26 PM
Yamaha 1997 200 SWS Fuel Flow NavMan 4380 kavika Yamaha & Suzuki Outboards 4 November 30th, 2004 07:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
