Re: Steering
A cable, & pulley sytem was the precursor to all the later model steering systems, it is all that was available years ago for outboards. There is nothing wrong with it, if it's in good shape, and installed properly. Generally if your engine is 100hp, or more, you might want to change to a newer better system. Installation is a bit tricky, but if you take your time, & think it out, anyone can do it. Just remember the powerhead of the outboard pivots to the right (looking from the top) as you turn the wheel to the right, (in a right turn) and the powerhead pivots to the left, when you turn the wheel to the left (in a left turn). Years ago a friend of mine put his boat in the water, off a rented trailer, and had the steering reversed, it was quite confusing for him while bringing it home to his canal, while trying to dock.
