Pardon the pun, but I am in the same boat as you, I bought a pontoon boat about 2 months ago. But I am starting to get the hang of docking it. You did not say much about your slip. IE do you pull in along slide like a dock, or pull in between two other boats, do you have finger piers etc. Also is there any current?
I dock mine parallel a dock, with a pretty swift current most of the time. I have found the best approach is for me to dock into the current at an idle speed, I wait until my boat is about 3/4 of the way along side slip before I start turning in. The key is to just have enough throttle to make headway.
Also ask around at your marina, I am sure someone will give you advice. I nknow that at my yacht club peolpe are always there to give advice and a hand.
