I have a 72 SeaSwirl with a bad Mercruiser 3.0L engine and trying to decide if I should rebuild or replace it with a complete late model 3.0L. I haven't been into the engine yet, but it sounds like it threw/broke a rod, clunk/knocking noise coming from the bottom of the engine. I was idling and took a 3' wave into the stern which caused the engine to die. The engine never ran the same after that and blew about 5-6 hours later. I guess the exhaust flapper was burned out, swamping the engine and bending a rod which eventually broke. That's my best guess
I'm looking at $1000+ to rebuild the engine, but if the crank or block are bad it could get pretty expensive, so I'm also considering a newer used engine if I can get one for a decent price.
I have a few questions about Mercruiser 3.0L compatibility
-If I replace the long block with a newer engine what years are compatible, 14" flywheel, large intake port head, engine coupler & crank? Am I missing anything important?
- Can I install a complete late model engine (engine, manifold, carb, ignition, flywheel, starter, alternator, coupler, engine mounts) into the 72 SeaSwirl without modifications? If not what modifications would be required? Do newer intake/exhaust manifolds have the mounting hole for the old style (72) throttle linkage?
The boat is pretty reliable since the outdrive was completely rebuilt 10 years ago then resealed along with bellows 2 years ago, head and manifold replaced 4-5 years ago, new alt, new starter, carb runs fine,,, $500 of new tires/rims week before the engine blew. I'm kind of perplexed as what to do since I don't want to dump a ton of money into a 73 boat, but also don't want to cheap out on the repair.
