- Apr 17, 2002
- 70,513
After the latest thread about using aftermarket exhaust manifolds,...
I decided it's time to do alittle more with mine...
My 4.3LX was bought as a Frozen core motor,..
I replaced the Block,+ welded the original mercruiser manifolds,...
While the welds held just fine,.. I knew I was boating on borrowed time,..
I bought a set of GLM cast iron manifolds off ebay, from a fellow iboater, pure coincidence,... I kinda thought that it was probably the same person, but it didn't really come to light til after the auction....
Anyway,.......
I finally got around to installing the manifolds in May of 06,.... They bolted on nicely,+were run up til this last fall,...
Toward the end of last season I was experincing some Hard starting, but blew it off til I was doing my winterization.....
That's when I discovered Water in the cylinders..... Not Good....
Of course, the 1st place I looked was the manifolds,+ risers,....
The evidence was hard to see, but after careful study,...
Ayuh, It was There,... Light rust tracks....
Of course that led me to find the "Why" part of it,... After all,... Brand New manifolds shouldn't be leaking,+ the risers still Looked to be in servicable condition,....
I dug out a flat file,+ struck it accross the tops of the manifolds,.......
Bingo......... The Problem......
You can see, the manifold on the right in the picture where I filed it, the file was touching Only on the outside edges,....
The center sealing surface is about .005 to .010 Low,... While that should still seal with the gasket,.. It did for awhile.....
Looking at the manifold to the left, you can see a small rust track on it's left inner sealing surface,+ the corresponding place on the gasket......
I'm heading over to a Bud's place today,+ He's going to resurface them for me,.....
If I had to pay a Machine Shop to do this,... I probably wouldn't ever buy another set of these GLMs,...
But,...
With the somewhat Free services I have available,...
I'd buy them again, in Aluminum,+ Inspect them Much, Much more closely.....
Good Luck with Your's.........
Anyway,.......
But,...
