Bob Nightingale
- Jan 24, 2008
- 3
Engine misses when accelerating from about 1200 rpm to 3000 rpm. This only happens after boat is is driven at low speed [1200 rpm or lower] for 5 to 10 minutes. Miss clears up slowly after about 300 yards of travel. I have had this trouble since the motor was new. Here is what I have done so far, spark plugs,stator,CDM,spark output [spark jumped over 1/4" when motor cranking] ajusted carbs and timing to Merc. specs,oil injection ajusted to specs, rebuilt fuel pump,rebuilt carbs,replaced 4 check valves,glass inline fuel filter,[no airbubbles in gas],no check valve in gas tank. Boat is a 20' Maritime Skiff with a 17" prop. ALL THOUGHTS ARE WELCOM, BOB
