  #1
Old March 19th, 2008, 09:28 AM
Expidia's Avatar
Expidia Expidia is offline
Send a message via Yahoo to Expidia
Default 2001 Evinrude 15 4 stroke ? good outboard
My Daughter is buying a 2001 15 4 stroke. I don't have the model # yet but it was supposedly the first of their 4 strokes. It's a one owner outboard and he has two boats so the smaller one did not get as much use. Freshwater use.
I've read a few threads here with a few issues.
I'll run it when it gets here on the muffs, but if it runs OK, what should we be aware of with this particular year?
I can do the simple stuff myself and I plan to change the gas filter (if it has one), plugs, impeller, the lower gear oil and the oil check the anode and then bring it to an Evinrude dealer for a go over like a compression test and clean the carbs.
Can a dealer hook it up to check how many hours on it with this model like the can the newer ones?
Anything else I should ask the dealer to do?
Worst case is I'd sell it on Craigslist ASAP if it's a problematic model and she could buy a newer one.
Bottom line is if it runs OK . . . Ya or Nay on this model?
Thx for any input
__________________
2007 Lund 1425 Classic SS
2007 40 hp Merc 4 stroke EFI ELPT
http://s198.photobucket.com/albums/aa2/expidia/
Sometimes you eat the Bear and sometimes the Bear eats you!
  #2
Old March 19th, 2008, 09:56 AM
JB's Avatar
JB JB is offline
Default Re: 2001 Evinrude 15 4 stroke ? good outboard
OMC built JohnnyRude 4 strokes in 8, 9.9 and 15HP in the late 90s, Expidia.
I had a '97 Johnny 9.9, which was essentially the same as the 15 but might have had a different cam and a different carb. The Service manual covered the 9.9 and the 15. It was a sweet li'l engine (about 107lb.) and I liked it a lot. Smooth and quiet at low speeds, easy to start.
Now, if what your daughter is getting is really a 2001 I don't know if that is the same engine or a Suzuki-built engine. I know nothing of the Suzi 15.
We need a model number.
__________________
RED SKY at night. . .
JB
  #3
Old March 19th, 2008, 10:03 AM
Expidia's Avatar
Ya, I asked her to get model and serial #'s before he delivers it.
Thx for the quick response.
__________________
  #4
Old March 19th, 2008, 06:35 PM
pukindog51 pukindog51 is offline
I have a 15 hp 4 stroke Evinrude long shaft.
Bought it new in 2002, electric start with remote shift and throttle.
I use it as a trolling kicker on 22 foot Crestliner Eagle.
Motor cover makes vibration moise no mater how tight you make the latch.
Other than that, it is quiet and smoke free.
Throttle is hard to get to adjust to just the right speed when your going from slow to just a touch slower or faster but I think all motors have that hysterisis problem. Sorry, I'm an engineer and that's how we talk.
It is really a Susuki with an Evinrude paint job.
Motor is expensive to fix, if you can find parts.
I already replaced fuel pump $102.
Very hard to change lower spark plug. You need to remove fuel pump to replace lower plug, which will foul if you troll at low speed exclusively.
I've heard this complaint of all 4 strokes.
I replaced power pack last fall. Over $400 with dealer labor.
Motor would refuse to troll after 2 hours.
I haven't tried it out since new power pack, so I don't know if it is fixed yet.
If I were you I would look for a Honda or a Yamaha.
I am trading mine in on a Honda if it is still screwed up.
Honda has a 5 year warranty. Evinrudes 1 year.
Evinrudes aren't what they used to be (when they were made in America).
Good luck but I've cursed at my Evinrude 15 many times.
  #5
Old March 19th, 2008, 07:38 PM
Expidia's Avatar
pukindog51, thx for your candor. This is great info. It's what I suspected anyway. I never buy used outboards myself.
I know from experience that people don't sell good outboards as they either never part with them or they get handed down to a family member or sold to a friend.
And I know what happens when you need to order a part and then wait around for a dealer to get around to installing it once it finally comes in.
I showed her your post and she said we should sell it and buy another one.
This boats already cabled for the evinrude, but I have not seen it yet and the cables might be shot anyway.
What I'll do is at least take the boat out for a spin and see how it handles with a 15 on it. I don't want to get another 15 if it's underpowered in the first place.
Last month I just sent my extended warranty in on my 2007 which extends it to 6 years. I'll look to have her get a Merc or a Yammy. I think Yammy has a 20hp. Merc only has a 15 and a 25.
I believe in going with the boats max rating from past experiences. So I'd like to go with the lightest 4 stroke we can find. I know Yammies are heavy in the larger models. I think my Merc 40 hp is the lightest in it's class. But I don't know the comparison with the smaller models yet. Many are the same body anyway like the Merc 9.9 being the same body as their 15, so we might as well get a 25 which is the boats max if it's the same weight as a 20.
With these small boats (it's a 14 Lowe side console) as soon as you put a third person in it's really too much for a 15 to handle in my experience
__________________
  #6
Old March 19th, 2008, 08:06 PM
4.0l sahara's Avatar
4.0l sahara 4.0l sahara is offline
most of the new evinrude/johnson outboards are great motors. They are still made in the usa and maybe the problems with this one are that they wern't made by johnson/evinrude?
__________________
Jeeps and boats.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2001 Mercury outboard 90hp 4-stroke jmorgan Mercury & Mariner Outboards 2 August 27th, 2007 08:08 PM
2001 225 evinrude ficht ram is this a good motor? ridefast104 Johnson & Evinrude Outboards 4 February 27th, 2005 06:23 PM
Yamaha 30 2 Stroke Outboard 2001 pdebruynkops Yamaha & Suzuki Outboards 4 November 21st, 2003 01:53 AM
2001 Evinrude 25 HP 4 stroke Hooper Johnson & Evinrude Outboards 1 January 22nd, 2003 08:36 PM
Evinrude 200 Ficht Ram 2001 Good or Bad Philwest Johnson & Evinrude Outboards 2 April 5th, 2002 07:44 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
