I was getting ready to order my parts for my 1984 Johnson 90 hp to re-seal the gearcase and I was wanting to post a list of the parts ordered to see if there is anything I am forgetting.
All part numbers are OMC:
- 0329923--Lower Seal
-0329922--Upper Seal
-0314728--Driveshaft bearing O-ring
-0388618--Cover Seal assy.
-0318372--Shift rod O-ring
-0324670-Cover Gasket
-0321463--Oil retainer
-0317178--O-rings
-0392750---Water pump kit w/housing
If you see anything I am forgetting please let me know.Also what type of Gasket sealant, Grease and Adhesive do you recommend because I can find the OMC stuff the manual calls for around here.
Thank you all for all the help yall have given me so far on this gearcase leak problem..
-0317178--O-rings
