Re: 1994 Evinrude 25hp e25reda Lower Unit drop.
i don't know what you disconnected under the carb. but there is a 1" x 2" plate side the side of the motor leg, with 2 screws, behind that is the connection for the shift rod. remove the bottom screw, don't drop it. then it should drop right out. when reinstalling besure the O ring is in place at the top of the drive shaft, the water tube lines up, and the shift shaft has a notch in it, that lines up with the screw hole in the connector.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
