I swapped my Sport Jet powerhead from a 95 - 97 The flywheel from 95 would not fit the 97 the hole is smaller on 95 so I am using the 97 flywheel. The only other thing different is the inner magnet for the trigger. On the 97 there are 2 groves 180 degrees from one another, the 95 has a solid magnet. The 97 had a CDM ignition the 95 had a CDI Switchbox ignition. Will the groves in the 97 flywheel have an effect on the 95 ignition components, mainly the trigger? I ask this because with this setup I am only getting spark when the trigger is advanced and only spark intermittently with the trigger in the neutral position. Thanks in advance for any help.
Ken
Ken
