tritonfisher
- Jan 22, 2008
- 2
I have a 2000 Johnson 130hp outboard. It runs pretty smokey at idle and often stalls out when trolling at idle speeds (like its choking out). It also cuts out at WOT. The extra smoke at idle leads me to believe that maybe the VRO is injecting too much oil...maybe stuck full rich?
Do you concur with this diagnosis? If so, can I check for stuck valves, debri, etc...on the VRO before defaulting to disabling the VRO completely and mixing my own fuel?...if so, where and how do I look? I've read several threads on disabling the VRO and think I understand if it comes to that with one exception: once you disconnect the oil feed line from the VRO, all the threads say to plug that intake...what do you plug it with?
Thanks in advance for any advice you can provide.
