78' Mercury 115 stuck in forward after LU removed
Ok, just replaced water pump.... when I took the lower unit off I turned it upside down to get a small rock out of it... the little plastic part fell out/off so I dont know what position it was in... I believe its called the reverse lock or something, it had a plastic washer under it..... I did put it in forward when removed but now its stuck in forward no matter what gear I have it in....... what position does that part go in.... how can I fix this.... thanks in advance...
__________________
I dont care how far away from the boat he spit the hook out, it still counts as a CATCH!... (since I was gonna let it go anyway)...right....
