sending block to the shop
Benny1963
evinrude 150 1983 still looking for tick.sending block to the shop. to get the pistons miked and the bores i over heated the right bank pretty good.
hoping i only have a couple of cyls that will be bored they are currently
o30 the bores have excellent finish on them my i should be looking for
out of round holes and piston correct .what is the the optimal clearence
between piston and wall finished , also do you know if they charge to mike the pistons and cyls if you give them the machine work.
also any tips in this area of inspection would be helpfull.
also any help on what to look for on rod bearings on both ends of the rods.
and mains journals and soforth.
thanks very much bennyb
