I'm doing some repairs on my "new" toy, but there are a few things I haven't quite figured out. My Clymers manual doesn't show enough detail.
I presume the linkage is meant to have a lot of flex for movement between the motor and housing.
Thing is, I've got a LOT of play in it, and I wanted to see if it needed bushings or if worn-out parts need to be replaced.
What is this roller on the end of the lever inside the housing?
It looks like a pin of some sort belongs in the shaft, but there wasn't. I shoved a nail in as a temp fix.
There are 2 screws that hold on the outer arm. Do they do anything but hold it on and provide adjustment? Looks like I may be missing a piece. Where might a find a diagram or a go-by sketch?
Thanx
Thanx
