Anyone with JB Weld experience?
gunner1
I have some holes in my aluminum boat that I want to use JB Weld Marine on. IS there a temperature that is too LOW for it to set up and harden at?
Gary H NC
Re: Anyone with JB Weld experience?
I think 60 degrees or above works best.You could use a heat lamp on it overnight and that would help.It cures pretty slow in warm weather.
thurps
Countersink or chamfer both sides of the aluminum to lock the filler in. Careful with the heat! Different coefficients of expansions.
Chris1956
Gunner, You might use a piece of glass cloth if the hole is more than 1/4". You can work the putty into the cloth.
Benny1963
my experience has always ended up having to weld but the others
worked for awhile .hope you had better luck than i
bennyb
tmcalavy
JB Weld won't set up and harden worth a crap below 55 degrees F. Above 70 degrees is ideal.
drewpster
My experience with JB Weld has shown me that JB Weld is best used as a trash can filler. Or it is good as a filler on the store pegboard. I like it best when I never buy it or use it for anything. Its really good for that.
Sorry for the sarcasm, but the stuff has let me down enough never to use it again. I have never, and will never, get it near my boat. (but thats just me):p
thurps
FG reinforced bondo or Devcon (aluminum filled epoxy).
ddennis
I used this
http://www.aluminumrepair.com/?src=google
to fix some holes and cracks in an aluminum boat that I had..works great! I was skeptical at first until I actually tried it myself. I am trying a repair on a prop with it now... ran out of oxygen on my torch before I could finish...
I found the epoxy 2 part putty you get at autozone works well for filling in gashes .It even works for stoping auto exhaust leaks as long as you clean the area well and have it dry.
iwombat
What is it that you are trying to fill? That would help a lot in determining a proper solution.
SgtMaj
If it's a tiny hole, a rivet might even do the trick. If it's too large, you'll have no good alternative to regular welding. JB weld is ok, but it's nowhere near as strong as the sheet metal, in fact, not even close.
jay_merrill
JB Weld is OK but it is far from a permanent fix. I have used it with succes in certain applications but I have had it fail rapidly in others. My opinion of your intended use is that it might be ok for a few days use on the boat if you prep the surfaces properly, cure it properly, etc., but you will have the same problem sood enough. For a permanent fiix, I recommend welding and/or riviting.
Bob_VT
A pop rivit coated with 5200 before you pop it will work. If the hole is from wear and tear..... patch the holes and consider gluvit on all your seams (which will almost NEVER cure in cold weather). Fiberglass does not work with aluminum....... it will seperate and always at a bad time.
gunner1
To be more specific, there is a line of about four holes in my transom that are about the diameter of a brad nail. My main concern is that although they are small, when I first put the boat in the water this past summer ( for the first and last time ) they let in alot of water. So now that I'm replacing the floor and looking into installing a permanent fuel tank, I want those holes properly taken care. I had seen those aluminum welding rods before, but was pointed in the direction of the JB marine. Perhaps the welding rods would be a better choice though, huh?
thurps
Bob_VT is right on. Make sure the pop rivets are the sealed type.
projecthog
If the tiny holes are the result of corrosion you have a bigger problem than you may think. The electrolysis effect will have thinned and weakened the original material to the point of near failure, and to apply JB to that will put you in a position to invite severe repercussions when out enjoying your boat, with the possible result of loss of life. When it comes to trying a cheap fix, I have, out of experience with problems of losing a boat, learned to bite the bullet and do things the right way. Get it welded or replaced with the proper methods and live with a much more satisfied feeling that you have done it right the first time. The hard thing I had to learn from my own experiences was that if I couldn't afford to look after or maintain a boat, I should have got something smaller or cheaper and simpler! My worst experiences taught me the most, as you would expect, but my standards as to messing with quick repairs or fixes has risen to a level where I will not.....ever, do anything to put myself in that kind of position again, and I have enjoyed boating to the fullest ever since. If this was an overkill message disregard it, as I don't mean to discourage anyone from having fun, but be aware of the possibilities of your actions, and lives of others.
Take care, PH.
ddrieck
I purchased an epoxy from Auto zone. Came in a tube that has the two parts seperated, kinda like a syringe. I used it on the plastic fuel inlet to one of the carbs on my 500-50 Mercury that I overtighten and cracked. It has held up for two seasons and is still holding fast. If this stuff will hold up and last for this application I would surely think it will last to keep out water.
i386
I've used JB Stik-Weld to repair some holes in aluminum rubrail. I probably wouldn't use it below the waterline unless it was a quick fix field repair.
JB weld has never held anything I have put it on. That is my experience.
Mike
