Model# 60173C, 1971 not 1073, fat fingers
I get intermittent fire on the spark tester. Great compression and all but troubleshooting the ignition.
Tore apart the control box and of course need to replece the connections as mild corrosion and going to replace the ignition switch also.
There is a little hard brown ball on a wire connected between the ignition switch and the push button gear selector, what is this? Iit was warm to the touch and when I used the vtvm meter it was drawing current with the key in the run position?
Also can I disconnect the wiring harness at the motor and fully eliminate the remote and turn the starter by touching the starter post to see if I am getting any spark. This will eliminate a faulty ignition switch if I am able to do this.
Do I need to jump any wires on the motor to get the ignition to fire if I eliminate the ignition switch for test purposes. Thanks for the replies,WAV.
