Reseating Railings
mikesmith6
Have an old(er) sailoboats and the toerailings and/or sheet traveler railings are leaking. How do you reseat railings ?
flashback
Re: Reseating Railings
Hello Mike, you will have to remove them in order to seal them up properly, It can be quite a job if you can't get to the nuts on the underside...if you have teak toe rails, you will need to remove the bungs to get to the screws..good luck...
