Quote:
Originally Posted by DANNYMC24
I purchased a 1989 Evinrude 150 that sat for 3 years. I got the motor running after some work. When I started it it was spraying a good stream of water from the tell tale. After running the motor for some time while trying to set the timing and checking it out I noticed that it was just dripping water from the tell tale. I replaced the propeller, houseing and all the gaskets for the water pump. I hooked it up to the hose and it again was working ok. I then went to the lake and after a few minutes it wasn't spraying again. What else could be the problem. I blew through the lines before I put it together. I also took the thermostats out and put the in boiling water to be sure they work and they opened and closed fine. Any help would be greatly appresiated. thank you
I did not see the words "I replaced the impeller" in your post or is it a typo where you said propellor ????
The thermostats usually open way short of boiling point so they may be suspect as well. Not sure what temp they should open up bu 140 degrees ish rings a bell with me. Someone will be along shortly that will know exactly for your motor.
