  #1
Old March 15th, 2008, 04:19 PM
JonTX JonTX is offline
Question Update: horn works - restricted fuel vent seems to be the problem, 89 Evinrude 150
We put this motor back together - all new fuel lines, fuel filter, temp switches and t-stats have been tested and work. In the driveway with muffs on the motor, after 5 minutes the horn alarms - solid tone. removed the wires from vacuum switch that is monitoring fuel restriction and horn stayed on. That switch has been tested with vacuum pump and it switches at 7" Hg. Next unplugged the tan wire from port side temp switch. Horn stayed on. Next unplugged tan wire from starboard temp switch - horn still on. Finally unplugged white wire from starboard switch and horn quit. I'm wondering now if the problem is the horn itself.
How can I test this horn and are there any other suggestions where to look next for the cause of this alarm. The motor sure does not feel hot. Thanks,...Jon
  #2
Old March 15th, 2008, 05:03 PM
ezeke ezeke is offline
Default Re: How to test alarm horn? 89 Evinrude 150 hp
I think the starboard switch is probably bad; The black and white wire is the control for QuikStart. It should not set off any alarm.
The way you test the horn is at the control by disconnecting the tan wire there. If the horn keeps sounding, the horn is bad. You have effectively already shown that the horn is good by getting it to shut off.
  #3
Old March 17th, 2008, 02:31 AM
Lightbulb Re: Update: horn works -restricted fuel vent seems to be the problem, 89 Evinrude 150
ezeke, thanks for the information. After reading your reply, i searched around to find out what QuickStart was and how it works. The problem we had in the drive way test was plugging in the wrong wires. The wires coming from the motor are discolored to the point you have to look really close to see which one is which. So, with the white and black wire from the switch incorrectly plugged into the tan wire going to the horn, as soon as the motor warmed up a little bit and was trying to tell QuickStart to dis-engage, that signal instead was sounding the horn. Getting the wires sorted out and plugged in where they belong solved that problem.
On to the lake test: Everything ran fine until WOT and shortly after that here comes the solid horn again. My buddy was trying to pump the fuel bulb to see if that helped and the bulb sucked completely flat and stayed that way. This is all new fuel stuff, completely back to the tank and the pick up tube is clear so we were pretty sure the problem was not in the fuel line. Unscrewed the fill cap to let it vent and made another couple of runs at WOT with no alarm. Pretty sure now that the vent is restricted some sort of way, kinked line or something. He had pulled the vent line off the tank earlier and was able to blow through it from both ends, so the only thing we can think of is it must be getting kinked somehow when it's installed on the tank. I can't think of anything else it could be but if anyone has any ideas, please let me know.
Also, we cant find any anti-siphon valve in this system. The pick up tube has a screen on the bottom, and the top of the tube goes into an aluminum block with a hose barb at the outlet for the fuel line to connect. There is nothing in that area - open passage all the way. Any other likely areas for an anti-siphon valve to be located?
Thanks to everyone who has helped so far in figuring out this problem.
  #4
Old March 17th, 2008, 06:33 AM
Theoutdoorsman's Avatar
Theoutdoorsman Theoutdoorsman is offline
Default Re: Update: horn works - restricted fuel vent seems to be the problem, 89 Evinrude 15
It is possible you have some crud in the fuel cell. I've seen many a foil cover from oil bottles fall off. I always remove them completely before adding more 2 cycle oil to the fuel. It might be sucking up debris and clogging the screen on the pick-up tube. Possibly one of these foil covers from a rogue oil bottle...... :-) ....... Also, if you have a kinked line, the restriction is likely to be between the bulb and pick-up tube. If possible, try cleaning the fuel cell.
  #5
Old March 17th, 2008, 09:44 AM
If I understand you, when you opened the fuel cap, the engine ran normally.
If you have a vent that goes through the hull, it may have a screen on the outside that can become clogged, especially if you are around salt water. You can pry the screen out with an awl or a sail needle and clean it, then shove it back into place.
Most of the anti-siphon valves are just a spring and ball bearing in the outlet barb at the top of the tank. Coast Guard regs require them if any part of the fuel system is below the top of the tank. If the entire system and the engine are all higher than the fuel tank as in many outboard installations, they are not required.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Alarm horn buttonhook Johnson & Evinrude Outboards 8 August 7th, 2007 11:52 AM
Alarm horn? bhile Non-Repair Outboard Discussions 4 May 17th, 2007 09:43 AM
Evinrude 90 Horse Oil Alarm Test joseywales Johnson & Evinrude Outboards 14 April 20th, 2005 07:34 AM
evinrude 110 horn alarm buzo Johnson & Evinrude Outboards 12 June 30th, 2004 05:41 PM
ALarm warning horn 1976 Evinrude 135hp willisballs Johnson & Evinrude Outboards 7 May 5th, 2004 10:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
