  #1
Old March 15th, 2008, 10:40 AM
DRBSJR DRBSJR is offline
Default Mariner Tachometer help
Hi
I picked up a Mariner Tachometer from a boat jumble and was wondering if anyone knew a little about it and could give some guidance before I tried connecting it up.
The Tacho is mostly black with white numbers and an orange needle, the writing on the face indicates:
X1000 r/min
MARINER
NIPPON SEIKI JAPAN
There are no serial/part numbers
This is the interesting part….there are 6 pins on the back and no selector, like you get on the Teleflex gauges.
There are 2pins towards the middle, I can only assume are for Positive and ground but they are not labeled. (HELP)
The 4 pin towards the bottom edge are labeled from left to right, 12, B, 4 and G.
There is a metal bridge between 12 and B but this could be moved to bridge B and 4.
I have 97 Mariner 60hp (3cycl) 2stoke….tacho connects via the gray wire on the 5pin harness from the control box(16900A15).
There is also a light with a blue and black wire…no points for connecting this up 
Any info on how to connect this tacho up would be much appreciated as I have trawled the net and found nothing on this gauge.
  #2
Old March 15th, 2008, 01:52 PM
Default Re: Mariner Tachometer help
I've dusted off the Digicam...hopefully this would get a responce
  #3
Old October 2nd, 2008, 08:59 PM
garry_hawley garry_hawley is offline
hsve fun my tach dont work either
  #4
Old October 2nd, 2008, 09:28 PM
i dont understand why merc and mariner do not give any info on line i have serched to no avail and about ready to give up on it maybe johnson os the way to go well if you find any info please fill me in thanks
  #5
Old October 7th, 2008, 08:41 AM
janneman's Avatar
janneman janneman is offline
Send a message via MSN to janneman
Lightbulb wire hassle
from looking at the pic....
i'm guessing the bridge is not to move, but just to combine battery. the two pins in the middle might have no function at all in electical sense, only to mount the gauge. mind you: "might"....
the two wires on top probably are for the light, and are hence polarity insensitive.
now you're left with exactly the number of wires you minimal need for a tach... plus (battery), minus and tach....
i'm guessing:
12 = 12 volt
B = battery
4 = 4 stroke / pole tach
G = ground (minus)
__________________
internet is a world without borders, where the hart is the only passport you carry (carlos santana)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Quicksilver Tachometer settings for Mariner DavidStonehouse Mercury & Mariner Outboards 3 March 13th, 2005 05:48 AM
tachometer for yamaha / mariner 55 el jurgenscraft Electrics, Electronics and Trolling Motors 1 December 28th, 2004 12:21 PM
tachometer problems on 92 Mariner 150 swebb0071 Mercury & Mariner Outboards 7 March 19th, 2004 09:25 AM
Sea Ray Tachometer on a Mariner Outboard mattyc Mercury & Mariner Outboards 0 April 28th, 2003 12:48 PM
Tachometer for Mariner ausrys Mercury & Mariner Outboards 1 November 7th, 2001 11:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
