about the most ignorant thing you can do is to bypass a clogged filter, means any trash/water now goes directlty into the engine.
I prefer the water seperator to be between the filter and the engine but its not critical as all it is is a primer, once the VST is full you can remove the primer and run forever.
if it collapses during running it means there is a restriction between the primer and the liquid level in the tank and nothing else.
but now its time to service the filter in the VST and the one on the engine, change the element in ytour racor as well.
keep running it lean and you will post about low compression in #1 cylinder
