Re: 2001 evinrude 35hp elan help!!
Your ? is quite vague, why would u want to mess with those wires inside the hood, get yourself some controls and hook them up and see if your problem of not killing the engine still exists, or is it a tiller? If your using controls the stoping of the engine is done with the key switch, also if it is a tiller you have a kill switch , check the connections all along that circut, also its always a good idea to check all your grounds when dealing with an electrical problem... good luck
