I'm rebuilding the carbs on my motor and noticing a few things after reading alot on here about it.
The carbs look clean, no gumming/oils, the metal is almost shiny, can they be dirty even when they look clean?
Also I got the kits and noticed on ishop's diagram that it shows two different orfices for the upper and lower carbs, but the kits just have one orfice only. Do I need to order the other one or should they be the same? I will take them apart and see if there is any difference between the two but wondered if I should get one ordered.
