Re: sound proofing engine compartment
i tried lots of stuff....
except of course most of the the things suggested here.....
the biggest problem i find with mine..is that the gunnels allow the sound thru...no positive blockage between the engine compartment and the passenger area....
i duct tapped plastic (where no one could see) in thoes areas...cut the sound in half....still too loud...used accustic celing tile...got wet..pink foam...broke...finally i did use the foil backed insulation.....it worked good on the dog house... but the sound still came thru the gunnels....i.dont want to hear the motor...(unless its knockin...then i really dont wanna hear it
im glassing a compleate new rear cover and using dyanamat plus whetever else i can thro at it to keep it quiet.....
the best motor noise is the one that you dont hear!
