MuskyHunterDave
- Jan 21, 2006
- 145
Hello. . . .
I recently purchased a 1975 Evinrude 70hp outboard with a "Outboard Jet" on it.
Model - L
Serial - 7227
24" drive Shaft (overall)
I am planning on setting it up on an aluminum boat to run in the Spokane River here, and while I am a very competent individual and able to do a rebuild, I have never seen or worked on one of these pumps, and am in need of some advice / information to assure a proper rebuild.
It was used in Brackish water prior to me buying it, so I want to go through it, and make sure it is in top shape before using it, but I am having trouble finding information on the pump. I have searched the internet endlessly, and while I had found "some" information, it is not detailed enough for a rebuild.
Can the aluminum housing be lightly sandblasted to remove the slight corrosion from the salt water / old paint (was brushed on), or is there a better way of doing it ?
Is there anywhere I can get a detailed "Exploded View" of the unit and how it goes together / comes apart ?? I found one online, but it was a little vague as to how the four bolts that hold the main bearing in, and how to remove the bearings. I ask because I removed the 4 bolts on the impeller side, as well as the split ring on the top side of the bearing, and I want to replace the seals and inspect the bearings, but Not sure how to remove the bearings (it seems Stuck). Also there where two grooves in the Drive shaft where it sits in the bearing, and one groove had a round split ring, but the other groove did not, should there be two??
There are four splines at the top of the drive shaft, but each look to be worn back in a little over an 1/8 of an inch so to speak in from the original vertical machining & about 1/4" short of the top and bottom of the splines. Is this normal wear, lube grooves or ???
I am not 100% certain on the above things, and want to make sure it is complete as well (no missing parts), so a complete parts breakdown, and any help you can give me would be greatly appreciated !!
I currently have it completely stripped down (expect the bearings & exhaust), and removed the two bolts holding in the exhaust tube, but it does not want to come out, is there a trick to that ?? I wanted to remove it and thoroughly clean the housing before rebuilding it, as it was run in salt water.
Is there an owners manual or repair manual in PDF format, any one know ?
Are there local dealers for parts / info, as the outboard jets web page does not list them . . . .
I live in Eastern Washington State / Spokane
Thanks in advance for the help, and have a GREAT DAY !!
Model - L
Serial - 7227
