  #1
Old March 11th, 2008, 07:55 PM
EricDickerson EricDickerson is offline
Default 1968 Mercury 200 20hp timing HELP!!!!
I purchase this outboard not running. I went ahead and removed the flywheel to inspect the points. To get my puller on the flywheel, i had to remove the bolts from the hub. Only problem is, opps, i forgot to reinstall the hub bolts before tightening the crank nut and in spun on the flywheel. There are 8 bolts, so 8 different ways the flywheel can go. My question is, is there anyway to tell on these motors. I tryed 3 different position. The engine will run now but not good. Are there any timing marks that i am missing. Help would be greatly appreciated. I only want to pull it apart one more time.
PS. This engine looks to have been used very little so i dont believe any of the linkages have been tinkered with.
  #2
Old March 11th, 2008, 08:09 PM
SpinnerBait_Nut's Avatar
SpinnerBait_Nut SpinnerBait_Nut is offline
A true iboats friend
Default Re: 1968 Mercury 200 20hp timing HELP!!!!
You have a PM.
__________________
http://banners.wunderground.com/weat...tlettsburg.gif
http://www.frappr.com/iboats
"JUST KEEP ON, KEEPING ON"©
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
  #3
Old March 11th, 2008, 08:18 PM
I am new to the site. What do you mean by PM.
  #4
Old March 11th, 2008, 08:29 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
A manual for your motor will contain the "link and sync" procedures. The first step in this procedure is to sync the timing pointer and flywheel with the position of cylinder #1. You will need a dial indicator tool (or similar) to do this step. The dial indicator step will show you if you have the flywheel installed correctly or not. Since you have removed the flywheel and related linkages, you must do all of the link and sync steps any way. If you don't, you risk damaging your motor if you run it and it is incorrecly set up.
Having said that, to just get close for flywheel installation purposes, you can check that the TDC mark on the flywheel generally aligns with the timing pointer when the #1 cylinder is at the top of its cycle. That is, closest to the spark plug.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
timing mark help for a 95 20hp mercury Bird hunter Mercury & Mariner Outboards 5 June 25th, 2009 11:59 AM
1968 Mercury 20hp chevy343 Mercury & Mariner Outboards 6 July 3rd, 2007 03:51 PM
Mercury 20hp 1968 Tomxx7 Mercury & Mariner Outboards 3 August 7th, 2005 02:21 PM
mercury 20hp 1968 Tomxx7 Mercury & Mariner Outboards 3 August 3rd, 2004 06:56 AM
MERCURY 20HP 1971 TIMING PROBLEM JCOUPLAND Mercury & Mariner Outboards 1 July 16th, 2004 05:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
