Got a new (to me) boat with the said engine. It will fire up cold and go no problem, but after it is warm, park it for a few hours fishing, and fire it back up, it will die. Basically after I have been fishing for an hour or so, it fires right up and runs strong for a few seconds, then the idle drops and it will eventually stall while it is in neutral. If I try to throttle up in neutral it will stall, and if I put it in gear it will stall. I can get it to run great again if I just wait 15 minutes or so or just gun it in gear. This is my first outboard and I use the boat in Hawaii so any help would probably save my life. Thanks!
