  #1
Old March 10th, 2008, 11:32 AM
jkering66 jkering66 is offline
Default 1988 175 Mercury - Stiff Steering
Hello,
last season my 1988 Mercury 175 outboard was very tough to steer. I took off the steering cable and manually moved the engine left to right and it is very stiff. I greased all the fittings I could find and worked the engine back and forth manually to free it up. It got a bit better, but after 1 week of no use, it is got very stiff again.
Do I need to replace some parts, or am I not getting it greased correctly?
Thanks
  #2
Old March 10th, 2008, 12:55 PM
ddennis's Avatar
ddennis ddennis is offline
Default Re: 1988 175 Mercury - Stiff Steering
Sounds like time to replace the steering cable. You may try to get one of the "cable buddies" and use it to lube up the cable real good. If the cable is that stuck there is probably more wear in it than lube can help...safer to replace it..
  #3
Old March 10th, 2008, 01:12 PM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Ayuh,....
It's entirely possible that continued Greasing of the Swivel Tube will loosen it up,.....
It sounds like it's Really Boogered up.....
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #4
Old March 10th, 2008, 01:25 PM
j_martin j_martin is online now
Quote:
It sounds like the engine is stuck, with the cables removed.
Cables should be greased anyway. They last forever if you can keep them lubed, and are expensive and troublesome to replace.
That engine is big enough to hurt you real bad if steering fails. Be sure you get it right. If it isn't dual rack steering, I'd replace it. The single bolt that ties the steering linkage to the motor is critical. Use the right one from Mercury, not a hardware store substitute.
hope it helps
John
  #5
Old March 10th, 2008, 04:46 PM
Chris1956 Chris1956 is offline
Once those motors get stiff steering, they are hard to loosen 'em up w/o disassembling the midsection. This is a lengthy proposition. Here are a few tricks. As you pump up the grease fittings, see which steering bushing (upper or lower)doesn't get grease. Now it is time to minipulate the motor to grease it. Usually it is the upper.
Tilt the motor up all the way and see if there is vertical play in the swivel tube (powerhead can move up a bit more). Now pump some grease into the fitings, if you can get it to come out the ungreased bushing, you may be able to grease it sufficiently.
In addition a bit of heat on the bushing may melt out the old dirty grease and allow new greasing to enter. If it is the botom bushing, you may remove the grease fitting and blast in some PB Blaster to loosen up the old grease.
  #6
Old March 17th, 2008, 12:41 PM
Thanks Chris1956,
Grease comes out the bottom, but not the top, will try what you recommended and heat also.
Was not sure if parts needed to be replaced.
FYI, when I disconnect the steering, the steering cable moves fantastic so it is definetly the motor part of the steering.
Thanks
  #7
Old March 17th, 2008, 02:08 PM
Wink Re: 1988 175 Mercury - Stiff Steering
This last happened to me in the fall. The upper bushing wasn't getting any grease. I tilted the motor up all the way and tied a piece of rope around the transom bracket and under the Anti-Ventilation plate. I used a stick to tighten the rope like a turniquet (bad spelling). This forced the motor up higher and allowed space between the transom bracket and the swivel shaft bushing. I was able to force some grease into the top bushing.
The steering is a lot easier, although I will not know if it is fixed until the spring.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Stiff Steering jv4studio Johnson & Evinrude Outboards 7 March 29th, 2007 01:07 PM
Mercury stiff steering. ninx10 Mercury & Mariner Outboards 2 July 27th, 2004 06:03 PM
stiff steering maxair Boat Restoration and Building 9 February 11th, 2004 06:07 PM
stiff steering and... maxair Boat Restoration and Building 1 February 10th, 2004 05:29 PM
Mercury Electric Hydraulic Steering is Stiff dboresky Mercury & Mariner Outboards 1 September 30th, 2003 06:01 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
